Question about HP Pavilion ZV5220US (PF143UA) PC Notebook
Bought 1G ram from local computer store. It runs for about 5 minutes then i get a blue screen error and reboot. returned to store for a different mem stick...same issue. went to Crucial, found the memory, customer reviews say they love it except the HP zv5000 series notebook....doesn't work. Called HP they dont carry the mem anymore....suggested i go to Crucial. Has anyone been able to upgrade the ram on an HP zv5000 series notebook?
  • kevink104 Aug 27, 2010
    One of the slots is not accessible, so the only option was to pull old ram and insert new.
    Brigadier General:
  • 10,406 Answers
Did you remove the "old" RAM, or did you add the "new" RAM to the old RAM?
Try using your computer with ONLY the "new" RAM installed.
Try using your computer with ONLY the "old" RAM installed.
Try using your computer with the "new" RAM in the 1st slot, and the "old" RAM in the 2nd slot.
Try using your computer with the "old" RAM in the 1st slot, and the "new" RAM in the 2nd slot.
Posted on Aug 27, 2010
My hp pavilion desktop is blue screening.
Is your computer infected with the XP blue screen error? This is the error that shows up as blue screen with white text, and there is usually no way to recover the computer, except to restart it. For some people, the blue screen may go away after that, but that was certainly not the case for me a few months ago. It kept reappearing regularly afterwards, and I was convinced that something was wrong with the system.
1. Why Does The Error Occur?
Once the blue screen error persist on your computer, it will not go away unless you fix it. The most common reason for the problem is errors in the computer registry. It contains all the instructions that instruct your program applications to run correctly.
2. How To Repair The Registry?
The blue screen problem can be easily fixed by using a registry cleaner, if your errors are caused by errors in the registry. This was exactly what I did to cure my computer. It does not only get rid of the blue screen, but you should also find that your computer performance will improve if you have never maintained your registry before.
To clean your registry, you will need to download a cleaner software and run a free scan to find all the errors.Here are some of the Best Registry Cleaners :Tuneup Utilities,Registry Mechanic,CCleaner.
If unfortunately, your computer problems are coming from the RAM, you will have to replace the faulty RAM stick. You can also test your current RAM stick by changing it with another working one, and see if the blue screen error returns. If the error still persists, it would mean that there is no problem with the RAM stick, and vice versa.
Oct 15, 2010 | HP Pavilion Slimline s3620f Desktop
When I shut down windows xp it restarts I stopped auto restart and got a blue screen with this disciption on it Stop: c000021a [Fatal system error] 0x00000000 (0x00000000 0x00000000). any idea
Click on my computer.
Right Click on the C: drive.
Choose Properties.
Tools tab.
Error checking: Check now.
Choose automaticly fix file system errors.
Start, Yes, OK, Reboot the PC.
On boot a blue screen will launch and run for 5 - 20 minutes.
It wll reboot into windows when completed.
Sep 27, 2010 | Microsoft Windows XP Home Edition
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
Won't boot up gets blue screen asking for us to
Usually if you've encounter a blue screen the first cause of this should be the RAM. Check the RAM maybe it is clogged by the dust you need to clean the RAM. If the same things happen you must reset also the CMOS battery and the jamper. The jamper located near the CMOS battery at the south bridge.
In any other circumstances to solve this you need to install a fresh copy of windows. Some causes of blue screen is the corrupted software that need a full copy.
Dec 02, 2009 | Dell Inspiron B130 Notebook
I upgraded my laptop's (hp compact cq40-336 tu) RAM from 1 GB to 3BG. I bought a 2GB RAM w/ Kinsengton model from our local store. TO find out the said RAM is not working properly. How can I fix this...
This model laptop requires DDR RAM. Sometimes different brand of RAM do not work together or not the memory upgrade was not compatible with the laptop.
To check the amount of installed memory, go into the BIOS configuration to view the RAM.
The other way is to open Control Panel and click on System, this will also show the total RAM installed.
Oct 17, 2009 | Compaq Computers & Internet
After upgrading RAM 1G to 1.5G
The BIOS will recognize the new ram when the pc is turned on. If the amount is being reported correctly and there are no beeps you are good to go.
Feb 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Blue error screen and system shutdown on Dell Dimension C521
Rule of thumb test ram out first usally that is the cause what does the code say on the blue screen
Feb 13, 2009 | Dell Dimension C521 PC Desktop
Upgrade to 1g RAM
take your old ram with you when you buy the new one, also you new to know if you new duel channal memory
or parity memory
or edo or non edo ram
most of the information will be provided by the vender of the computer. hp tell you everything it is , duel channel, edo, non edo, parity and non parity memory than take the information you have on hand to fry electonics store or online to egg head.
pay alot less for the same memory they were going to charge you and arm and leg for..
rod is the candymangandy
Feb 03, 2009 | ASUS P4S800-MX Motherboard
Erratic behavior - system halts with blue screen with error codes
sounds like serious memory errors. download and boot to "memtest86" to terst your ram for errors, but it may also be the memory controller.
you can try also to swap slots between the memory sticks and see if it works better with the sticks swapped.
Oct 15, 2008 | EliteGroup KN1 SLI Extreme Motherboard
HP Pavilion ZV5220US (PF143UA) PC Notebook Logo
91 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
