Question about Hotpoint Dryers
Dryer sqeeks, are the places to lubricate?How do you get to them?
  • Hotpoint Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed.
Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Aug 27, 2010
Dryer is making a lot of sqeeking noises, is the glides or the bearings?
Hi twvarga...
Note: This method works with most front loading machines.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3inOne oil. Reassemble the dryer, plug back in. This should solve your noise problem.
This is a FREE answer, Please rate me
Apr 21, 2011 | Frigidaire GLGR642A Gas Dryer
I have a frigidaire stackable washer and dryer one solid unit the dryer will sqeek really loud when the drum turns but it sqeeks in the same position every time. but it does sometimes and sometimes it does...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Feb 01, 2011 | Frigidaire Dryers
Why does my dryer make loud sqeeking noises while running
pulley and motor.
3 in One oil.
Please rate me
Dec 07, 2010 | Frigidaire FGR641F Gas Dryer
Model # DBSR453EB2WW; sounds as if belt needs lubrication when operation dryer, high pitch sqeeking. Please advise.
The belt is attach only to the motor pulley and a tensioner pulley one of which is most likely in need of replacement...you could oil or grease them but that probably wouldn't last very long or work at all...??
Apr 19, 2010 | GE DBSR453EBWW Electric Dryer
I need a manual or somebody to tell me how to remove the back of my hotpoint dryer. Model DLL2650BGLWH. It sqeeks really bad and I was told it's prbably a shaft or bearing. Also, can I just try to...
Disconnect power to dryer.
Take screws out above door, allowing dryer top to swing up and back.
Remove screw near top from side panel into front panel, allowing front panel to be removed and set to the side.
Some models have a very small access panel at the very center of the drum on back, which may hide an " E " clip on the drum shaft, which would have to be removed, all other dryers no longer use them. Lift dryer drum up slightly and pull it forward a couple inches. (you do not need to remove the belt) Remove all the loose washers / sleaves on the back shaft of the drum and install a new WE3X75 rear drum bearing, then re-install drum. (no need to put the E clip back on.)
Check the drum slides on the bottom front side of the drum. Most times, if the rear bearing is in need of replacement, so are the front drum slides, especially the one on the left (blower / motor) side.
Just trying to lubricate it will not solve your problem.
Feb 18, 2010 | Dryers
How do i repair my maytag from squeeking
remove the front exterior panel. The seal around the drum must be clean and have no crease. If so the seal will produce a sqeek. Also the belt around the drum must be tight and the roller bearing on the belt tensioner must turn freely. If the roller is out of round the drum will rumble and if the bearing is dry or jambed the dryer will sqeek as well
Feb 06, 2010 | Dryers
Maytag legacy series dryer sqeeks almost shreeks on every rotation of the drum...is there a way to lubricate the drum and or a drive belt? where can I find a diagram to fix this?
I use non flammable oil. Zoomspout oil is HVAC approved and heat resistant. $2 at any ace hardware. The drum must be removed to get to the wheels. The one closest to the exhaust is the one that usually makes a statement. LOL Here are some repair photos that give an idea how to get in the dryer. It is srongly advised that you do a thorough cleaning of the innards whilst making the attempt to quieten down the squeak. Oil the idler both wheels and whatever else you see in there that might could use some oil. That is what I do.
Some repair photos: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 09, 2010 | Maytag MDE2400A Electric Dryer
Kenmore Elite Dryer making a sqeeking sound when on
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 01, 2010 | Kenmore Elite HE4 Electric Dryer
Makes a sqeeking noise while turning or on bumps
Suspension problem like a rubber bushing. Try recreating it, have some one push up and down on the front fenders one at a time, asuming the noise comes from the front. Try and spot where is coming from, if the part looks good spray it with lubricant not penetrating oil. Is best to replace what ever is making the noise.
May 11, 2009 | 2006 Chevrolet Equinox
Squeeky tape deck
With the top off get hold of a flexable tube. One of those drinking straws that has a bend will do and place one end in your ear and search for the noise (like a stepescope). You might see what's causing it then.
I suspect that grease would not cure it. But try Silcone (from Maplin's (UK) or other type store, if you think it might need grease.
Nov 28, 2008 | Sony TC-WR565RM Single Cassette Deck
Dryers Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
