Question about Homelite Carburetor Trimmer Blower 308054001 Mightylite
I have a homelite blower. It is getting fire and too much gas for its on good. What do i need to do to the carb. to keep it from flooding out before it even starts? Thanks
  • 211 Answers
SOURCE: Homelite Blower HB180V carb adjustments.
Hi
high speed H=2 turns ,lowspeed L=2 1/2 turns
they are inscripted near the adjusting screws.
regards savumihai71
Posted on Dec 05, 2008
sparksflyin
  • 47 Answers
SOURCE: oil/gas ratio for a modle UTO8110 homelite leaf blower
you can run 32:1 if you want to it wont hurt it but it may foul a plug since its more oil, 50:1 is the best ratio for your blower
Posted on Feb 05, 2009
slohry
  • 87 Answers
SOURCE: need oil gas mixture for homelite HB 100 blower
50:1 with premium oil i.e. Echo, Stihl, Husqvarna.
40:1 with Homelite or generic brands
Posted on Apr 12, 2009
  • 109 Answers
SOURCE: Getting the right tool to adjust carb on Homelite Blower.
Type in "AYP" on google...scroll down to "jackssmallengines.com, in the AYP part number box type number 530035560.
Posted on May 12, 2009
SOURCE: Homelite 2 cycle backpack leafblower won't run.
Sounds like the exhaust port is clogged with carbon/oil buildup. My three yr old Craftsman Blower/Vac did the same thing and all I could think of was the carburetor or fuel lines were clogged. But after replacing the fuel lines and air blowing out the carburetor it wouldn't start and then when it did start it only idled. A friend suggested I take off the muffler and cylinder head. Clean out all the old carbon and oil buildup from the exhaust port. It was so clogged up that maybe a bb could have only passed thru. Once I removed all the carbon, put it back together, it fired right up, idled like it was brand new and went to full speed with no problems
Posted on Oct 01, 2011
Getting gas plug is fireing but will not run
I would take the carb. off and clean it. there is a small hole in the bottom of the carb take a stick pin and clean it as well
May 13, 2014 | Homelite Consumer Products Backpack...
I have this exact blower and it doesn't seem to work anymore. It worked last week and when I try to start it up using the start up procedure it doesn't start. It has enough gas/mixture and is primed. I can...
Hi, this sounds like a wiring issue. If there is fuel supplied to the engine and the spark plug is good, you should be able to get it to fire. However if there is no spark due to a broken wire or faulty kill switch you will not receive a spark. Also, if you are certain that all systems are in order, you may have simply flooded the engine and the gas needs to evaporate from the various chambers. If it is flooded, you may also try starting in full throttle to compensate for the extra gas. This sometimes works. Good luck.
Nov 16, 2010 | Homelite Mighty Lite Blowervac
Blower will run on choke but not in the run postion
If you haven't tampered with any adjustments (Set screw, Idle, Hi or Lo jets etc...) then most likely your carb is flooding. You either have something stuck in the needle valve passage keeping it open. (And it can be Tiny! and I mean a speck.) You can try shooting some good old "Gumout" or any other carb cleaner/ degreaser made for carbs. Try removing the gas line off the carb "Inlet" and with that hose off spray the carb cleaner into that hole liberally. Pull the throttle open and close fast as you do the "spray in".If you have compressed air? Send a little of that in there after the spray, then spray a bit more cleaner in. Let it then sit for 10 15 min loaded with cleaner. Then reconnect the gas hose, prime it up with the primer bulb, restart it, let it warm up a bit. see what happens. Oh FYI to much oil (or the wrong type)in the gas mix can sometimes cause something very similar to flooding. So make sure all is correct!
May 10, 2010 | Homelite Consumer Products MightyLite...
Hi guy's by blower won't start or fire i think jet settings are wrong could this be
Unless you have fiddled with the carb, it's not the carb. Check spark with an in-line spark checker then check compression with a compression tester...if these two test good THEN it may be the carb. If you need to know how to use those tools or where to get those tools, let me know here.
Jan 22, 2010 | Homelite 'Yard Broom' Leaf Blower
I have a homelite model uto8550 26cc mighty blower/vac. On initial startup it runs at half choke then stalls when i turn it to run. Any suggestions?
1. check fuel filter in gas tank (for clogged condition).
2. Check carb jet for dirt (squirt carb cleaner in jet and fuel inlet
Summary: your carb is not getting enough fuel to mix properly with constant air flow. Therefore, fuel supply needs to be cleaned... then you will run happy!!
-Jim
Oct 23, 2009 | Homelite Consumer Products MightyLite...
Gas is pooring out of the exhust
Needle valve in the carburetor is not stopping the flow of gas. It may need to be rebuilt. You also may have flooded the unit trying to start it.
I would have a shop do a compression test on the engine; it needs to be at least 100 psi to run.
Sep 30, 2009 | Homelite Consumer Products Backpack...
HB-180 Leaf blower won't start
if its flooded then it surly wont fire,not a 2-stroke. are you over priming or is there a malfunction. remove plug,put plug not a tester in the end of lead,ground, and pull. spark should be purple and consistent. if red/yellow/intermitent. change he plug. if the engine is only flodding on its own then the needle and seat could be stuck open in the carb, gas tank vent in fuel cap plugged and building tank pressure, or fuel mixed too rich. let me know what you find
Sep 02, 2009 | Homelite Consumer Products MightyLite...
Blower stall after few seconds
sounds like you not getting enough gas,or you are getting air in gas line,, check for air bubbles in gas line,, if you dont have any then clean the carb. good,, hope this help you
Aug 29, 2009 | Homelite 'Yard Broom' Leaf Blower
My homelite super 2 chainsaw keeps flooding. it was running fine and all of a sudden its flooding. any help is welcome
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to homelite.com to find manual for the saw.
Apr 15, 2009 | Homelite ZR10926 16 Chain Saw
yea check the gas lines and throttle cables for strech, probably need replacing or tightening.
Jan 03, 2009 | Homelite Consumer Products Backpack...
Homelite Carburetor  Trimmer Blower 308054001 Mightylite Logo
132 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
