Question about Linksys Wireless-G WRT54G Router
I have a WRT54G router and want to daisy chain a Linksys BEFSR41 switch off it, but I seem to be doing it wrong...
  • 3,289 Answers
1 Power up and hard reset BEFSR41 to factory default (192.168.1.1) settings.
2. Connect a computer to one of BEFSR41's four wired LAN ports
3. Log on to the BEFSR41 by typing 192.168.1.1 into browser address box.
4. Setup
a. Change Device IP Address to not conflict with WRT54G (assuming 192.168.1.1 for WRT54G), other static addresses on your network, nor should it be in the range of the WRT54G's DHCP server addresses. 192.168.1.2 is likely to be a good choice for an address - if not in use on your network.
b. Select Apply
5. DHCP
a. Set DHCP Server to Disable
b. Select Apply
6 Connect a CAT5 cable between one of the numbered LAN ports of the WRT54G and the UPLINK port BEFSR41 (if yours lacks an UPLINK port - connect to one of the numbered LAN ports instead). There should be NO connection to the WAN/ Internet port on the BEFSR41. Do not concern yourself with WAN / Internet page settings on the BESFR41, because they are not connected.
7 Reboot the computers so they can get new, unique IP addresses.
Please rate this reply - good luck!
Posted on Aug 27, 2010
    Scholar:
  • 92 Answers
Not sure if you just want to expand the amont of computer you can connect to it or the wireless range but I would setup the BEFSR41:
  • Disable DHCP
  • Set an address out of the DHCP scope of the WRT54G
  • Connect them LAN to LAN if not use xover to connect them
Can i hook my westell 327w to a linksys befsr41
Absolutely, it is as simple as plugging in the westell to the befsr41. However all that will do is split the cable so it can accomodate multiple devices. BUT, the befsr41 is a wired router, to go wifi pick up a wireless router. This wireless router replaces the befsr41. I like the linksys (Cisco) 1000 or the 2000. If they have the Wrt54g thats best. Good luck! Dont worry it is pretty simple.
Jan 01, 2012 | Computers & Internet
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Need proper setup for linksys befsr41 to xbox
If the router is already set up, all you should have to do is run cable from router to xbox. Xbox should be set to automatically detect settings.
Nov 14, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Opening Port 123 on my Linksys BEFSR41 Router
Hi:
It turns out I didn't need to open port 123 on my router to get SymmTime to work.
Thanks for the efforts
Brad McMillan
Dec 16, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Router install ok, but don't connect to internet
if you are from the east coast,you need to configure your new linksys router for a ussername and password which is usually provided to you by your Internet Service Provider
if you are from the west coast,after you connect the new linksys, you must be good to go for internet usage.
Dec 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys router befsr41 model
Since you do not know what has been changed. I would suggest you to reset everything.
I am not sure about your particular model.
But generally, Linksys routers have a small hole called "reset". It should be at the back of your router.
Use a pin, press the reset for few seconds (~30).
Now, everthing is reset.
You the setup CD which came with your router and set it up again from fresh.
hope it works :)
Sep 25, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
NAT
First, you need to get into the user interface for the router.  To do that, just open your web browser, type in 198.168.1.1 & hit enter.  A login prompt will pop up if you're able to access the router.
If you've never done this before, the username is blank & the password is admin
What, exactly do you want to do with the NAT firewall?
To enable/disable NAT: click on setup, then click on advanced routing.
To filter Internet NAT redirection: click on security, then click on filters.
You can find this information in the User guide provided by LinkSys at:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859876500&displaypage=download
Select your version number, then click on User Guide when it comes up.  User guides & Interfaces for the BEFSR41 are almost identical on every version.
Oct 27, 2007 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys Wireless-G WRT54G Router Logo
1,211 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
