Question about 1995-1997 Chevy Suburban Ignition Starter Alarm switch
Removed am radio which was working fine installed a am/fm with amp removed from a 95 pickup,plugge on the floor before installing in dash work ok installed in dash and now i have no power at all reinstall am radio works but no has no memory
  • 1 more comment
  • dykejeffrey Aug 27, 2010
    the second radio uses the same plugs as the am radio
    radio removed was factory delco am
    trying to install delco am/fm from another vechicle
    both radios are delco
    Brigadier General:
  • 3,489 Answers
It is possible and most likely you blew a fuse. Should be fuse 17. Do you need an owner's handbook? If so, email me at iambanshee74@yahoo.com and I will send that right to you. What year exactly so I get the right one?
Posted on Aug 27, 2010
  • 3,083 Answers
I'm thinking you have a power problem in your wiring. Not sure about your radio's make, etc., but I know the memory wiring has to come ahead of the ignition switch to allow power continuously. Perhaps you blew a fuse to this wire, or shorted it out and opened up a fusible link? Not sure, of course. Sure does sound like a problem occurred when installing the am/fm and amp, and perhaps it could have been a crimped wire.
Wish I had more ideas, but problems like this are really tricky.
    Sergeant:
  • 252 Answers
Ok you have two in line fuses one goes to your battery the other goes to your ignition switch. The wire running straight to your battery is your memory wire. Check both of your radios to see if they have fuses on them if they are blown replace and make sure non of the wires are exposed when pushing radio in dash. Im sure that all you have is a blown fuse. Some fuses on aftermarket radios or located in a black or red box connected to the ACC wire iat the back of the radio. Pry open the box to see if fuse is blown
  • 905 Answers
Most radios will have 12 volts coming in on 2 wires. 1 wire goes to the ignition, and provides the bulk of the power required for the radio. The 2nd wire provides power to the radio all the time, so that the memory feature and clock are not cleared / reset. I would venture that you have got the 2 wires backwards, and have blown a fuse in the fuseblock when the 2nd radio was connected. Also, the 2nd radio (with the amplifier built in) may draw too much power for the wiring harness in the truck, and may require a dedicated power wire coming directly off the battery (fused of course).
Double check your wiring (particularly if you are having to splice wires together, then check for blown fuses.
I have audiovox Sirius radio from 2004 and still works fine. I am having a problem finding a frequency setting while driving from phila. Pa. To Newark de. Can you help me with a frequency setting that...
I use a wired fm modulator that the fm antenna passes through. When the sirius radio is on it blocks the regular fm signal preventing local signals from interferring. Do a search for wired fm modulator and you should find one. Mine actually fit inside the dash on my pickup.
Jan 06, 2013 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Model-m 255 clarion installed in a pontoon boat. RADIO WAS WORKING JUST FINE, THEN I INSTALLED A (NEW) BATTERY FOR MY BOAT, HOOKED EVERTHING BACK THE SAME WAY. NOW, I HAVE POWER BUT (NO) SOUND...
Disconnect all the speaker leads and then hook one speaker (a new, known to work speaker) up directly to the radio using a short (6"-12") piece of speaker wire. Does that speaker work then?
Jan 03, 2011 | Clarion M255 AM/FM Marine CD Player
The am/fm Delco radio on my 1993 chev pickup is locked on 1:00 time and 98.1 fm. This does not appear to be an anti theft condition that I have read about but it did happen after prolonged cranking &...
I have the same issue. I removed the reciever box (16147075) which is located under the dash right behind the ashtray. They hooked up another GM radio and it work. So I am going to replace the reciever box. Here is a pictuce of it.
http://www.oem-auto-accessory.com/receiver_box.html
Sep 03, 2010 | 1993 Chevrolet K1500
No am radio but fm works fine
I don't know why you need AM, but that's not the issue.
If you have FM and HEAR it ok, then everything is fine. You've hooked it up right.
Not being able to find AM, is in the new radio.
You need to look to see how to tune to AM.
Maybe the paperwork that came with it!
Jan 13, 2010 | Dewalt DC011 AM/FM Radio
95 Buick Century dash removal?
you should not have to remove the dash to install a new radio all you have to do is remove the trim around the radio and then take out the bolts that hold the radio in and remove the wires from the back and also if there is a Walmart or Radio Shack near you get an installation kit and you plug it from the plugs from your old radio and it is alot easier to wire it that way
Mar 04, 2009 | 1995 Buick Century
Radio switches between AM, FM, and CD
Check fuse no. 18(20 amp) in the under dash fuse panel. This is the fuse that keeps power to radio at all times to keep memory alive.
Feb 04, 2009 | 2006 Ford Fusion
Sony CDX-GT310. Installed by Circuit City about 15 months ago. CD works fine. No sound from radio (both AM & FM). I've manually tuned through the range of stations with no reception. Checked...
Called a shop in VA and their opinion was that the tuner section of the unit failed. Cost of the part, $80. Then, labor and shipping. I can buy the new model (GT320) for about $95. I opted for buying a new unit.
Aug 11, 2008 | Sony CDX-GT310 CD Player
Radio doesn't work anymore
For a wiring diagram go to an auto parts store and get a repair manual, about $15-18. Or just go and get an aftermarket stereo at Best Buy (or wherever). They will have what you need to install it. The sound will be MUCH better.
Apr 23, 2008 | Car Audio & Video
My FM radio is not working after install ......
Hi , you may buy a portable fm antena adaptable in car body .
and install connect to antena plug and then good fm signal.
Nov 14, 2007 | Sony CDX-454RF 10-Disc CD Changer
1995-1997 Chevy Suburban Ignition Starter Alarm switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
