Question about Northstar Generator 9 Hp, 5500 Watt, Gasoline
Hello, Bob here. Trying to repair my NorthStar 5500. The generator has no output. (distrobution box disconnected) looking on the output directly from the wireless generator. Do these go bad and are there replacable parts inside them? Is there external controls that make them put out? Thanks. I'm shooting blind, no diagrams.
  • Robert
    Robert Aug 31, 2010
    please post a ser# of the set as well as a ser# of the gen gead thank you
    Scholar:
  • 97 Answers
On the end of the rotor their is a Diode as well as a varistor these will go bad common in these units and cause a power loss these are attached to the rotor by a strip some like a pc board some a insulated tang to say remove the 2 one on each side Diode part# 778959 varistor part# 778961 manufacture numbers you should be able to go to any electronic store like radio shack and cross ref the numbers as to the diode i don't have the spec's but when you find it it will have the voltage rating get the next size up it is better to go to a higher voltage what the diode does it acts like a 1 way valve power flows one way and if their is a spike it wont allow it to come bach and damage parts before it it will also act like a fuse to sorts to much it will pop. the varistor varies the flow their sensitive and adjustable if purchased from other than manufactures factory it will need to be adjusted hope one is good and use a multi meter and test the Resistance and adjust the new one to that spec as close as you can at the end plate their is a capacitor part # 778958 replace this as well again go a higher volt rating but do not change the MF value with this said and done.your will have a more stable sign wave and beefier circuitry able to hold up better use lock tight on the screws for these.ther is not any control in the box with the plugs just breakers after replacing these parts and there is still no power then the stator is shorted and will need either re-winding or replaced.
hope this helps.
Posted on Sep 01, 2010
Northstar 5500 watt generator lost power to outlets and is squealing loud at the generator side of unit, there is no switch for output
squealing either bearing,bushing or winding going or gone if bushings or bearings might be able to repair if not to damaged
Aug 29, 2016 | Northstar Electrical Supplies
Northstar 5500. Voltage good. sounds and runs good. But, makes bad noise from gen head area when under any load. I replaced the bearing. Anything else?
Stator is contacting the rotor, did you replace both bearings? remove the stator and look for damage on the stator and rotor laminates
Feb 26, 2015 | Northstar 5500/4500 Watt CARB Compliant...
North star 5500 generator works fine but on voltage output
It's very common for the connectors between the alternator and power outlets to come loose on these. Give them a check and tighten as necessary.
Oct 13, 2014 | Northstar Generator 9 Hp, 5500 Watt,...
My north star 5500 generator starts but does not put out any electricity through the plugs
Check the connections between the alternator (generator) and the regulator/output connectors.
How much output can i get from northstar 5500 ppg generator
there are two things in generator out put
one is max out put which is 5500 in your case and another is rated out put which should be about 4500 in your generator Max out put should be used only for a little time say half an hour otherwise generator is suppose to run on rated load or rated out put which is 4.5 kva or 4500watts in your set that also when you are in Ideal conditions means if you are at the sea level if you are above in altitude you can calculate that engine will loose its efficiency at the rate of 3% after every 1000 feet altitude inthat way you can calculate how much rated load you can put on the generator
Jun 30, 2012 | Northstar Generator 9 Hp, 5500 Watt,...
Generator runs fine- does not produce any power- checked breakers all ok
The voltage regulator for the generator is not work, replace it. Why, if there no dc voltage to excite the stator it won't any output. GB...stewbison
Aug 31, 2011 | Northstar Generator 9 Hp, 5500 Watt,...
Hi output from generator
I found out that the gasoline motor was turning too fast so I had to turn down the speed of the motor with the adjustment screw.
Sep 06, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Low output from NorthStar 5500PPG
There are a few scenarios that can cause this.
1) The extension cord that you are using is too long / too light of a guage. Try a heavier extension cord, or plug directly into the generator.
2) The alternator has lost its "residual magnetism" and may need to be reflashed. Consult Northstar for instructions and details.
3) The voltage regulator (actually a simple capacitor) may be "weak"
4) The diode for field winding may be bad.
You can get a copy of your manual here, page 40 has diagram and part numbers.
http://www.northerntool.com/downloads/manuals/165911.pdf?cm_ven=natural&cm_cat=netconcepts&cm_pla=Google&cm_ite=http%3A%2F%2Fwww.google.com%2F%26
Apr 02, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
North Star 5500/ lost one leg of the 220v
Small generators like this almost always have 2 stator windings 180 degrees out pf phase, that's how it makes the 220.
At the back (maybe side) of the outlet box should be a molex type plug that has the wires from the stator, get an ohm meter and measure them (with the generator shut off of course). You should find that you've got 4 wires in the plug, 1 wire for each end of 2 coils. From one end to the other of each coil you should measure less than an ohm, between the coils there is usually no connection, but some models have the neutral ends of each coil connected together inside the generator housing.
It sounds to me like you've got one of the power windings open...
Carl
Oct 13, 2008 | Northstar Generator 9 Hp, 5500 Watt,...
Northstar Generator 9 Hp, 5500 Watt, Gasoline Logo
509 people viewed this question
Top Northstar Electrical Supplies Experts
John Trevino
Jim London
Jim London
Are you a Northstar Electrical Supply Expert? Answer questions, earn points and help others
