Question about Kitchen Ranges
I need an instruction manual for a opal 32 egurko ortza. where can i get one?
Need to find user guide and owners manual
Hello;
I have lost the user manual to a Panasonic TX-32LXD700 32" TV. Does any one know of a link to download a copy?
Many thanks to any one who can help?
Feb 10, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
Opal 400 heart rate monitor- need the chest strap or company web site to try and order a new one
Your Opal 400 is produced by Echowell Electronics Co. LTD.
Unfortunately, there is no downloads for your particular model. They now have a similar model called RUBY 400 and the setting instructions may be the same, but I'm not sure about that.
So, follow this link and ask them to email you manual for Opal 400. You may be lucky to get one:
http://www.echowell.com.tw/contact.php?page_id=18
Rate me, please.
Aug 13, 2009 | Watches
How to cut the rca opal-mp4002 on?
Once it has charged for the 3 hours, unplug the player from your computer and hold in the Play/pause button for 5 to 7 seconds, until the player turns on.
-Tha Mp3 Doctor
Dec 27, 2008 | RCA OPAL M4001 MP3 Player
Its actually an rca opal M4008
myspacepepe this just worked for me. Try downloading the firmware here:
http://www.fixya.com/support/t322643-rca_opal_m4008a
Then read this solution another user posted. Hopefully this helps you. I had the same issue.
I had this problem. Backing up data wasn't a concern though, as I hadn't anything on the OPAL yet.
First I let the OPAL charge up for 3 hours. Then I made sure it was powered off. I had previously downloaded onto a PC the firmware update for the M4004 which also works on the M4008 and other OPAL's. I plugged the OPAL into the PC, and booted up the PC. After installing the firmware package in the PC, you get an install screen for the new firmware with a format option for the OPAL. I selected that option, but the "start" button was greyed out as the PC still couldn;t see the OPAL. I pressed the reset (paperclip in the back of the OPAL) for about 15 seconds, than held down the "Play" button and waited. Eventually the software recognized the OPAL, and started to format it.
If you get a dialogue to restart the PC, press NO! You have to read the instructions that come with the install. Eventually I reformatted the drive, and installed new firmware.
BTW, there was no picture folder after I did this, so I just created a new folder named picture and it worked fine for the thumbnail pics I threw in there. Also when I use a MAC with the OPAL, I power the MAC up with the OPAL off but attached. After drag and dropping files into the OPAL, I power down the MAC. After power down the OPAL will after a pause give the "building databases please wait" messages, then when done go to the start menu. It is difficult on a MAC to eject the OPAL, it just reappears on the desktop so shutting down is the only safe way to administer the device. But to update firmware, which is easily corrupted BTW if you unplug the thing at the wrong time, you HAVE to do it on a PC operating system. Might work on an Intel MAC with a PC OS though.
Hope this helps.
Jun 03, 2008 | RCA OPAL M4001 MP3 Player
Moving files to Windows media player for transfer to opal mp3
You should be able to just drag and drop the folder into either the media player, or directly into the opal. To drop files into the opal, just click the my computer icon on your desktop, then after the window opens you should see the opal icon listed with the other drives you have. Then open up your folder with the music, highlight the ones you wish to move onto the opal, and drag and drop the file over the opal icon. If you did it correctly, windows will show you that it is copying the files to the opal. Good luck and enjoy!
Apr 05, 2008 | RCA OPAL M4001 MP3 Player
"My Computer" won't detect Opal
1. you should have your opal plugged in when your doin something with your opal on your computer. i got a question have you ever dropped your opal? you might need to take it to a mechcanic so it can get fixed or exchange it for a new one.
Mar 25, 2008 | RCA OPAL M4001 MP3 Player
Need help
What problem do you have?
Jan 31, 2008 | RCA OPAL M4001 MP3 Player
RCA Opal M4008
This is the BEST solution. I just had the same problem and ran across this solution and it actually worked. If you are experiencing this problem, this is the only fix I found and I have tried several. Solution #2 posted on Dec 30, 2007 4%20stars_w.png
Billy_K
Rank:nonexpert_s.gif Apprentice
Rating: 95%, 9 votes
Hope this helps.
Dec 28, 2007 | Audio Players & Recorders
RCA Opal M4002 MP3
The same thing happened to me.(I have a different model but I'm sure you can solve it the same) Go to the website and download the frimware thing and it will completly clean your MP3 of data you added. At least it did for me.
Oct 07, 2007 | RCA OPAL M4001 MP3 Player
Kitchen Ranges Logo
114 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
