Question about Cycling
Having trouble removing the handlebar stem on a kulana sunfish
  • 4,102 Answers
Hi, you know when you undo the bolt in the middle that runs down the center of the stem well instead of undoing this all the way undo is a few turns so its raised slight then get either a rubber hammer or use a piece of wood and a normal hammer then hammer the bolt down then undo a bit more then hammer it down a bit more doing this releases the pressure on the sliding part that locks the bars this will then allow you to pull the stem out.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 27, 2010
Schwinn 12 Roadster trike-handlebar does not fit into fork steer. Handlebar & fork have approx. same circumference, so can't slide it in. Is the handlebar defective & needs to be replaced? Thanks!
I assume you mean the handlebar stem does not fit into the fork steerer. Approximately the same diameter is not good enough. The stem has to be the correct size for the fork. The two most likely sizes are 22.2mm and .833 inches (21.15mm). Most stems have the size stamped near the bottom. There's a good chance your trike has a .833 steerer. Stems for that size are still available.
Jan 25, 2018 | Schwinn Cycling
Raising handlebars on schwinn ditch 2.0 dn
The above answer is incorrect. The Ditch has what is called a "threadless" fork/stem setup. One cannot raise the stem at all unless there are spacers above it. Raising the stem is also not the only option. A stem with a shorter "reach" may be sufficient. Google "threadless stem riser" to see options for raising the stem. Following is a video with the procedure.
Jun 09, 2016 | Schwinn Cycling
How to raise handlebars
There is a black or gray rubber plug in the handlebar stem that you can pull out with your fingers. Use a #6 Allen wrench to loosen the stem wedge bolt (only loosen, do not remove!) this will enable you to lift the handlebars and stem up. When you have it at the desired height, tighten the bolt back up with the Allen wrench. Note: on the side of the stem is a "minimum insertion mark" do not raise the stem high enough to be able to read this, if you do then it is too high. The stem could break or come loose if you raise it above this mark and void any warranty.
Apr 06, 2016 | Electra Bicycle Company Townie 21
My steering his still and cranky I think my bearings have gone not sure how yo undo the head case
Mark:
I don't know what type of bicycle you have, or how modern it is, but the handlebar and steering head are similar on most models. Try to remove the handlebars and steering head from the bike as a unit. There is a large nut at the top of the head tube (where the steering stem goes into). Loosen this nut, and the handlebars and steering stem should pull up and out of the bearing inner races. When you completely remove that nut, the headset will come apart... (including the fork and front tire which will drop out of the headset. If your brake and shifting cables are too short to let you pull the steering stem completely out of the steering head, you'll need to remove the handlebars from the steering stem. If you are careful, the bearing set, spacers and washer will stay on the fork tube when it comes out of the bicycle frame head, so you will know which order to reassemble them in. Either tag them or lay them in the proper order. Now you can clean the bearings or replace them.
It would be a good idea to clean the bearing races at the top and bottom of the steering head too.
Once everything is cleaned and ready to reassemble, grease the bearings and the bearing races and reassemble. When you tighten the stem nut down, make sure that there is no play between the steering head and the steering stem.
Feb 09, 2014 | Cycling
Adjust handlebar height on Schwinn Varsity
I'm answering 7 years later. I have a Schwinn Varsity 2500 Bike made probably in 2015. The Schwinn Varsity Bike is not set up the same way as a traditional bike. I loosened the center compression bolt and the two side stem clamp bolts and it came loose where I can adjust it up or down but, there's nothing to tighten the slack up below. I did some research. My original post here was to add or remove a spacer. I think you can remove a spacer to lower but, I don't think the stem is long enough to add another one. I've seen they sell an extension that you can add-on to make the handle bars higher.
Jun 25, 2012 | Schwinn Cycling
How do you raise the handlebars for the animator first bike by Giant bikes?
David-
To raise or lower the handlebars, first loosen the hex screw on the top of the stem. One or two turns is all that will be necessary. Next, you will need to stand in front of the bike with the front wheel between your legs to brace it, and give the handlebars a forceful twist to the left or right. This action will break the friction of the handlebar stem and the headtube (the headtube is part of the frame where the front forks and the handlebar stem meet...). With the handlebars loosened you can adjust the handlbars up or down. Keep in mind that the stem has only a specific amount of adjustment available...there is a limit to how far it can be extended up, as indicated by a line marked on the stem shaft. Once adjusted to the desired height, check that the handlebars and front fork and wheel are aligned. Tighten the screw in the top of the stem and you're done!
Hope this helps.
DIYpro
May 03, 2011 | Cycling
There's a ring nut between the stem of the handlebars (The stem is the vertical part of the handlebars) and the frame of the bike where the handlebars connect into the frame. The handlebar stem goes down through the ring nut into the frame.
Loosen the ring nut and you'll be able to raise the handlebars. There's a mark on the handlebar stem which indicates the highest point that the handlebars can be raised to. If you raise it above this there won't be enough of it in the frame and this can cause the stem to break when pressure comes on it. Also when tightening the ring nut up again make sure you have the handlebars and front wheel lined up.
Jan 16, 2011 | Cycling
I would like to raise the handlebars. I have loosened the stem wedge nut and the handle bars will not budge. I've tried everything almost to the point of losing the ball bearings in the steering shaft. Are...
Hey joe - Sounds like you have a classic stuck stem. Here are a couple things to try.
1 - Loosen the stem through the top bolt so the wedge is loose, but not removed. The give the top of the stem a good hit or two with a plastic mallet. That should break the bond between the steerer and the stem. If that does not work...
2 - Use liquid Wrench and drip around the stem so it seeps in-between the stem and steerer. Let sit a while then try the plastic mallet again.
sometimes you will need to work the stem back and forth a bit by using the handlebars as leverage and bracing the front wheel between your knees.
If neither of these get your stem loose, then it's time to take into a bike shop.
BTW - stems have a maximum insertion/ extension. There is a line of max extenstion that should be on the shaft when you get it removed. If you discover that the stem will not raise your handlebars enough, then you can get a replacement stem with a higher shaft and greater angle to lift the bars up.
Nov 11, 2010 | Cycling
How do I rotate the handlebar stem on gmc yukon xl road bike?
If the stem is installed backwards that means it is pointing at you when you are riding? To correct this you will need to remove the handlebars from the stem. This done by removing the two allen bolts front the front of the stem. Now loosen the two(may be only one) allen bolt heads on the side of the stem. Now rotate the stem. Reinstall the handlebars, front mounting plate and bolts (make sure the bolts are tight). Make sure the stem is straight and tighten the allen bolts on the side.
If the stem was installed incorrectly it may be a good idea to have the bike checked over by your local bike shop to insure nothing else is installed/adjusted incorrectly.
Hope this helps. If you need any other help you can contact me at elijah@starbikesfl.com Thank you
Jun 13, 2009 | GMC Yukon XL Road Bike
Cycling Logo
42 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
