Question about Dishwashers
SEWAGE SMELLING WATER COLLECTS AT THE BOTTOM OF THE DSHWASHER.
  • 4,323 Answers
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Please post back for any further assistance.
Daniel
Posted on Aug 27, 2010
My td c700e no longer collects water in the condenser but comes out of the bottom. why?
at bottom on the back pannel should be a trough that water collects in.............there should also be a micro switch and a float.......when float rises it trips micro switch that starts pump to send water to the collectin tank.........
cheers
Jul 31, 2014 | LG Dryers
What is a septic tank?
A septic tank is a key module of the septic system, a small-scale sewage handling system common in areas with no joining to main sewage pipes provided by local supervisions or private houses. Like TGWasteWater.com
Jan 28, 2013 | Plumbing
Water in washing machine drum
I shall give you some tips for cleaning the washing machine and clearing the smell
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1182/smelly-washing-machine.html
Oct 19, 2011 | Washing Machines
I have a Kitchen Aid side by side refrigerator. Under the refrigerator there is a plastic water overflow tray. It collects water and the water becomes foul smelling. I have tried removing the tray to...
You should be able to remove the base grill by opening both doors to 90 degrees and pushing down while pulling outwards on the base grill to unlock the top clips, once the top is away roll the base grill toward you and up. From there you should be able to see the pan underneath which should slide out.
Clean it thoroughly and use a mixture of baking soda and water for final cleaning rinse and replace, I also mix some baking soda and water and pour in the bottom of the fridge to allow the mixture to cleanse the drip tube leading to the pan.
Installation is in reverse of removal
Mar 12, 2011 | KitchenAid KSCS25FKSS Side by Side...
WIXL 125 the rubber seal around the door has mould at the bottom where thre liitle hole is. It has stained and there is water sitting around the area. Can we replace the rubber and why has this...
Yes, the seal can be replaced, and the reason for the mould is that you are doing too many low temperature washes.
You should periodically do a max high temp wash to help keep the seal clean and stop it from smelling.
Jan 31, 2011 | Indesit WA 125 Front Load Washer
Clothes smell like body odor after washing. using tide ultra he2 detergent.
i had what sounds like a similar problem. i complained of our laundry smelling sour then finally like sour sewage and a flooded laundry room. i was told that when its not draining properly, it can create a siphon-effect and actually pull the dirty water back out of the drain lines-yuk! i hope this isnt true.
there was a baby sock stuck in the pump preventing it from draining properly. hope your problem can be remedied as easily.
as for the smelly clothes, i always add 1/2 cup white vinegar to each load. it does wonders for odors.
Aug 13, 2010 | Washing Machines
Water collects under crisper drawers
Does it have darin at the bottom to drain out the bottom of the frifge into the drip pan? if it does push a wire threw the hole with the unit unplugged.
Aug 28, 2009 | Refrigerators
Dshwasher has water on the bottom after cycle
your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Dec 08, 2007 | Kenmore Elite 45986 Front Load Washer
Hi
Check the bottom of the machine and where water goes,there might be some scrap food,or other item that is not allowing the water to go in the time when the valve is open.This leaves some water and increases in other cycles,causing flooding on the floor.Also check for bend in the pipes at the back.
Hope this helps
jay
Nov 17, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishwashers Logo
116 people viewed this question
Top Dishwashers Experts
Owen Barnes
