Question about Mitsubishi WD-52525 52" Rear Projection HDTV
RE: Mitsubishi 52525 still green light
Wow! I'd rather put that $ into a new TV! I've called a repair service and it's going to be picked up tommorw... We are hoping it is nothing costly like what you have mentioned.... I'll keep you posted and let you know if what you think it is, really is wrong with it.
Thanks for your time!
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on May 22, 2008
I have a Mitsubishi WD-52525 television, purchased in Jan 2004, and have had various issues with the set since purchased. When the set was first purchased, it took three different deliveries to get a set...
Buy a new set - not a Mitsubishi DLP. I've repaired 3 sets at the board level.
Many, many bad capacitors on four boards, 12 hours to repair.
If a tech replaces one board, he is only fixing one of 4 bad boards and the set will soon fail again.
Apr 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Green timer light wont go away
The TV is in protect mode because there is an internal fault.
The TV must be tested and repaired at component level.
Call Mitsubishi at the number listed on the user manual.
You can also read my comment explaining more on protect mode here:Why my TV does not start up and remains in...
Dec 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
50 in mits tv wont power on. green reset light
Hi, It's either the lamp or the power supply capasitors. Thanks.
Sep 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV gets vertical colored lines, then shut off, green blinks conti
Bad Capacitors in the Power Supply could cause this. This Chassis has be famous for bad capacitors through out many boards. If you are not comfortable with working on the unit, and most are not, I would call a professional. The Chassis may need to be sent to Mitsubishi to be refurbished. This is a expensive repair and it would be advisable to call a Mitsubishi Professional to confirm diagnoses. Mitsubishi's Customer Service Number is 1800-332-2119. They also may be willing to help with the cost of repairs.
I hope this helps,
Jul 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Same problem on 18 month old Mitsubishi
As an experiment..plug the tv out of the wall. Wait. plug it back in. Does the green light stop blinking? If so, then the TV needs to go through setup/netcommand again. If not, the problem may not be an easy fix.
Jul 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsub replacec 52525 lamp. green timer light blinks then red steady light.
I have exactly the same problem and just had a tech leave after a $145 service visit. The cause is a problem in one of the 12 circuit boards that make up the electrical chassis (newer models only have two boards). I was given a form stating that some parts are no longer available for the first generation Mitsubishi DLPs (2004 build year). In that case, the only option is to have the entire chassis removed shipped to Georgia and refurbished. This can take up to two months and some sets have had to have this done multiple times.
I have to wait until tomorrow for news on whether the part is available or a chassis repair is the only option, and the costs. But it's looking like I have a $3000 paper weight after only 3 years (warranty was one year; the store's extended warranty was only two years). I will must likely just have to go out and buy a new set which will NOT be a Mitsubishi
Nov 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Constant green blinking timer light
Suspect the DM PCB part # 934C116002
Jan 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
59 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
