Question about Cub Cadet Garden
When PTO is engaged, amp light comes on and battery is drained. When shut down, the engine will not restart due to low cranking amps. Where do I look to resolve the issue?
3 Suggested Answers
  • 38 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
  • 5370 Answers
SOURCE: Cadet LT 1045; PTO not
The electric PTO clutch on a Cub Cadet L1045 allows the mower blades to engage. The electric clutch is located directly under the engine and is bolted onto the crankshaft. When the PTO switch is placed in the on position, an electrical current is sent to the PTO clutch; engaging a brake which then allows the blades to turn. When the PTO switch is in the on position and the blades will not turn, the electric PTO clutch may need replacing. Check the 2 wire conection under the frame near the pto clutch, motor off of course. Make them tight.
First start by turning ign on,then switch on the pto switch to on. you should hear a click in the clutch. If not use a twelve volt test light,hook aligator end to a good ground and the needle end,touch to the pto switch harness to see if you have power to the pto switch.If you don"t, you have to go checkfurther to your power source,(battery) if you do have power there check to see if you have power at the plugin at the end of your wire harness, just at the beginning of where your cluch connects up. You can test you clutch by conneting a test wire from positive on your battery to one of the terminals on your clutch and the other terminal to ground . It will engage if it is good .--------- But if not then by pass the pto and see if the clutch gets engaged.If it gets then replace the pto switch, but if its not engaging by bypassing the PTO switch then problem is with clutch, it has to be replaced. ------------ This will help.Thanks.Helpmech.
Posted on Aug 29, 2011
Shut down problem
im betting the center pto is still engaged still , this is a safety system (no start with pto engaged) I come across once in a while , not many folks use the center pto so it gets forgotten till somehow the engage lever gets set there , or sometimes it sticks in too
that's the simple thing I can think of , it only gets more deep from there
Jun 24, 2015 | Garden
Engine powered down going up hill then recovered, PTO stopped, now engine will not turn over
safety switch,unhook the ground wire from coil,if it starts then a safety switch is bad,also might need a new ign switch.
Apr 21, 2015 | Garden
Odd experience: engine powered down going up hill, then almost stalled. PTO will not engage, now engine will not start or even turn over.
I had a similar experience and I had to replace the PTO.
What size motor do you have and what brand is it?
Apr 21, 2015 | Cars & Trucks
When engage pto notice that voltage on battery drain is that cause bad pto
Can be if its coil is partially shorted. These usually 5-7 amps current-wise.
Disconnect the pto clutch wire connector at the pto clutch assembly. Using multimeter do a ohms test on the engagement coil. If it reads less than 1.5 ohms then it is partially shorted.
I have seen clutches to work even pulling up to 15 amps when partially shorted which more than most small engine alternators can produce.
Mar 30, 2015 | Garden
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
When I engage the PTO clutch, the amp light comes on my 1641 cub cadet. I have new battery, pto clutch and stator. I can mow for awhile, but when I turn the PTO clutch off, I can't engage it again because...
You need to repair either repair a poor connection from the alternator[stator], or replace the rectifier/regulater.Some systems have a inline fuse check that first.
Nov 07, 2009 | Garden
Garden Logo
301 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
