Question about Vacuums
I am looking for a site that will show me the parts for my flotec emergency water powered backup sump pump system # FP480WBU skew # 2231533528
Why is the new water pump I received from your company june 6, for my mightypro not the same as the original pump...wires and size totally different
Ma'am we do not sell parts here. We are a site of experts whom freely give our time to help figure out problems for our guests and help them try to fix it. Some of our experts will recommend other sites for parts. I would recommend looking on the receipt that came with the pump and contact the seller.
Jun 12, 2017 | Rug Doctor Mighty Pro X-3 Ready Pack...
Shop vac is not pumping out water just fills the canister
The question makes perfect sense assuming we are talking about the ShopVacPumpVac. These devices are, essentially, a combination shop vac and sump pump. For those answering the question, you can see literature on these vacuum/sumps here: https://www.shopvac.com/includes/streamPDF.asp?loc=pdf&id=Shop-Vac-Pump-It-Out .
When I have experienced the loss of drainage, I have found a couple obvious problems and solutions.
First, make sure that the garden/discharge hose is not kinked at any point along the line from the vacuum to the outside. If kinked, the line will not drain.
Second, the baffle can become blocked or clogged. Take the following steps to determine if your baffle is clogged and to clear the clog:
1. Turn off and unplug the vacuum.
2. Unclip the two lid clips.
3. Lift the lid of the vacuum. When properly set up, the baffle hangs below the filter housing on an opaque hose about 1 foot in length.
4. Grasp that hose and pull firmly downward. Once removed, I take that hose and the attached baffle to an outside garden hose.
5. Pull the baffle off the opaque hose.
6. Spray water from your garden hose through the opaque hose to make sure it is clear.
7. Spray the baffle clear.
8. Lightly tap the port of the baffle, where the opaque hose has been inserted. Most of my clogs have been the result of hair balls (or worse) at this point. Just tap any blockage out and rinse.
Third, reattach the baffle to the opaque hose. Reattach the opaque hose and baffle to the motor under the filter housing. Set the vacuum top on the canister. Click the locking clamps closed.
If this doesn't result in clearing the clog and allowing it to drain, then you are in the exact spot I am right now. If I figure out this new problem, I will update further. But I have cleared this kind of clog maybe five times in the six months I've been using this new Shop Vac Sump Vac
Sep 08, 2011 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Have water ace 1/2 HP sump pump does not always shut off. Can I fix this?
float switch might be no good, I would start with that
Mar 24, 2011 | Vacuums
Looking for plug for water go in s3501
Here is a tip that I wrote about how to find the parts you need for your Shark
How to Find Shark Parts and Accessories
heatman101
Dec 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How do i turn the pump on to pump out the water this is a 16 gallon 5.75 peak horsepower wet dry vacuum.
If you want to get water that's in your vacuum, OUT of your vacuum, you simply need to remove the top and dump the water out. As far as I know, the Shop-Vac 962-16-00 won't "pump out" any water that's in it.
If you want to pump water from one place to another (for example, your basement to your backyard), this vacuum doesn't pump water "through" itself (like a sump pump) - it will, however, **** water up. You just need to dump it out once the vacuum is full.
Jul 08, 2009 | Shop Vac 962-16-00 Ultra Pro Canister...
Bissell power washer 1694 shampooer
First off is the gasket on the bottom of the tank vavle or sitting in the hole. It has to be on the bucket. May have a problem with the handle not pushing the valve (in the handle)open when you squeeze the trigger. Check the back end of the top cover to make sure it hasn't broken loose from the base, if it has, that raises the top so water won't dispense from the tank. The draw back is that Bissell has obsoleted some parts for this model.
Sep 20, 2008 | Bissell Powersteamer 1694 Upright Vacuum
Leaking from bottom
It is the steamvac pump that is bad. When you fill up the tank with solutions, even though it is not running the solution leaks out, and when you turn it on it sprays up and out the sides etc. Also the attachment doen't work either, no solutions comes out. Apparently the float sticks in this. My husband fixed it once, and now he can't, need a new part. Options are take it to a hoover service dealer, or I found 2 place online that sell the part. One is http://buyitnow64.stores.yahoo.net/hostrepufor5.html and the other is http://www.sweeper-city.com/ho5brstpu.html, this site if you look at different size pumps have a description of the problem: "If your Hoover Steam Vac is leaking or water will not come out of the attachment hose, then this is the part that you probably need !!!
This part is for F5914-900 model. Hope this helps
Aug 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
82 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
