Question about Citrix SonicWALL Internet and Communication Software
Windows XP, Vista, & 7, installed citrix client 12.0.3 on each of them. When using direct connect through cable modem, access is allowed and all apps work. When connected to my local router(trendnet wireless) I can't complete the connection to the virtual desktop on the citrix server. I assume the router is blocking access. Using my firewall software, I am able to monitor port access, it sends to the ip adress on the server end using port 443 on the receiving server. There are many addresses opened on my end using TCP. What method, if any, do I use to get the router to allow the traffic?
    Sergeant:
  • 223 Answers
Because you can connect outside of your trendnet, its definitely the problem. please allow and direct traffic on port 3389 in your trendnet firewall.
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Did 3389 do the trick? dD you need further clarification or help? Please use the solution rating if your problem has been solved, make a note if your still having trouble.
    Thanks! Gurvy
Will not allow me to access my flash drive
Windows XP, Vista , or Windows 7 should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
If you have an older operating system then go here to download the driver:
http://www3.pny.com/categories/usbflashdrives.aspx?category_id=12
May 02, 2012 | PNY 8GB v220w USB 2.0 Flash Drive
I have hughes net with an HN9000 modem installed and I'm trying to use it with a D-Link DI-524 wireless router. When everything is connected, I can connect to the router, but Local Only. When I click...
Make sure you use the correct cable between the router and the D-Link. If you use the blue wire it won't work. The orange and orange white pair have to be swapped with the green- green/white pair on one end of the cable only. Usually, the cable is orange in color and is called a crossover cable.
Apr 16, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Does Go To Meeting work with Windows 7?
Here are the system requirements:
or PC-based Organizers and Attendees
  • Required: Windows® 7, Vista, XP, 2003 Server or 2000 (Linux is not supported)
  • Required: Internet Explorer® 6.0 or newer, or Mozilla® Firefox® 3.0 or newer (JavaScript™ and Java™ enabled) . If needed, download Java here.
  • Internet Connection Required: Cable modem, DSL, or better recommended
  • Recommended: Minimum of Pentium® class 1GHz CPU with 512 MB of RAM (2 GB of RAM for Windows Vista)
May 15, 2010 | Citrix GoToMeeting
How do I set up my router with out the disc? It won't run because it is Windows 95 not vista
if you connect the computer to the modem, does it work ?
If that works then the modem is working working properly.
now connect the modem and the computer to the router. open the set up page of the router.
here you can change the settings of the router.
You don't need CD to set up router
Click here to know more about how to set up router.
Jan 09, 2010 | Linksys Wireless-G Broadband Router
I need Huawei smartAx X MT882 driver for windows 7
Well..i can give you a torrent link to the driver location. Before downloading the same you need to download a torrent client. Its available free of cost over the net.
Nov 26, 2009 | Microsoft Windows Vista Ultimate Edition
How to connect usb conection from my data one "UT-300R2U" modem to compaq laptop.we have usb cable and driver cd but drivers are not installed in my laptop.plz give me the complete solution for this...
If you are using Windows Xp, just connect the modem using USB/LAN it will be automatically detected & software for it will be installed. Then you can just set up a connection, put in your username & password, done.
If you are using Windows Vista / Windows 7, modem in LAN mode will be installed automatically like XP, but not in USB mode. Because there's no USB driver for UT300R2U (BSNL modem) in Vista. You need to find a ZTE Remote NDIS device driver, install it & then you can connect. Hope this will fix your problem.
May 12, 2009 | Computers & Internet
Connecting modem via ethernet cable
I'm not an expert in window based units but since it worked with Vista OS and not with XP. Sounds like you might try re-installing XP again. Take note on any windows that refer to the ethernet port during installation. It is likely you might of hit "next" without reading all the text. I know I have in the past. I changed over to mac and I know longer have any problems only at work but give then I give it to the IT Dept and wait and wait and wait.
Sep 05, 2008 | Westell Wirespeed LiteLine 6100...
I recently purchased a Hawking HSB2 Signal Booster. Two years ago, my son installed a Toshiba Cable modem(PCX2200)and a Belkin Wireless Router(model#F5D7230-4)for Camcast High Speed Internet. The Router...
Booster will only work along with access points in your case the belkin wireless router - you have to connect the device to the router not to the windows xp pc
if you know how to configure and the device are compatiable to each other and allows bridging or can configure as your access point client then you need not wanna to get it connected via wire or T568b standard ethernet cable otherwise you have to connect with this cable will enchance the wireless activity
Wireless signals can go down its strength by any magnetic activity, oscillations such as microwave, powerful steel/metal frames and check your anteena position keep in different direction and check your pc wifi signal strength.
Interlink between your router and booster with utp cables gives you steady flow of data and full band strength.
Aviod using two company devices change the router to Hawking
Thanks Hothawk
Jul 24, 2008 | Computers & Internet
Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Feb 24, 2008 | NetGear WGR614 Router
Citrix SonicWALL Internet and Communication Software Logo
192 people viewed this question
Top Citrix Computers & Internet Experts
xxxxxx xxx
alibaba69
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
