Question about Watches
Can not turn off alarm setting. - Watches
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Timex expedition wr100m alarm
    TURNING OFF A TIMEX IRONMAN (the wr100m is the one I made this work on) ALARM: hold "set" to set each alarm to "on," not "hide." exit. flip through the modes until each alarm shows. don't hit "set," hit "start" or "stop." it should then switch from showing as daily or whatever to showing as OFF! good luck. so, UNHIDE, SHOW ALARM, DON'T SET, STOP -> OFF.
    May 04, 2012 | Timex Expedition Watches
    How do I turn off the alarm on my Armitron watch?
    I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
    Nik.
    http://home.earthlink.net/~eldonenew/armitron.htm
    or
    http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
    Other People Are Reading
    Setting Date, Time and Alarm
    • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
    Using Chime and Alarm
    • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
    Backlight
    • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
    Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
    Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
    I can't turn the alarms off on my Casio GW-330ca
    Setting CASIO G-Shock Watch 1) Home City
    2) Home city and Setting the digital time
    3) Adjusting hands
    4) Alarm set/on/off 5) Snooze 6) Hourly Chime A --- B ( ) Button reference C __ D
    1) Select home city first (if equiped):
    Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
    2) Set time, Date, etc:
    Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
    3) Adjust hands (if equiped):
    Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
    In Timekeeping mode B is illumination and D is time/day/date display advance.
    4) Alarm set/on/off
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
    Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
    5) Snooze (SNZ) Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
    To stop any alarm, press any button. To cancel next snooze, Press C and go to either the timekeeping screen or the snooze alarm screen.
    6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
    Press D to select hourly chime (SIG). Press A to toggle chime on and off.
    May 09, 2009 | Casio G-Shock G2600 watch
    Turning alarm offI
    how do I turn off the hourly setting
    Jan 19, 2009 | Casio DB360G-9A 30 Pages Telememo Watch
    Wacky wake up alarm clock instructions
    Hold down the "time set" button until the time on the clock flashes. Then use rev or fwd to set the time. Press the "time set" button again once you have the correct time. You can do the same to set the alarm by holding down the "alarm set" button.
    Jan 03, 2009 | Watches
    I just got a Freestyle Tide Watch 3.0 for Christmas. I set the alarm, and now I don't know how to turn off the alarm. It only seems to give me the option of which days I want the alarm to go off, no...
    I had the same problem. Emailed Freestyle support, it's pretty simple: Go into the alarm setting, and before you do anything else, push the reset button. That'll clear it. If you push the set button first, that'll put it in the set it mode, and the reset button will just advance you to the next setting.
    Dec 26, 2008 | Freestyle Shark Tide Data 4 Alarms All...
    Casio G-Shock 7510
    1) Home City
    A --- B 2) Home city and Setting the digital time
    ( ) 3) Adjusting hands
    C __ D 4) Alarm set/on/off
    5) Snooze
    6) Chime
    Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
    4) Alarm set/on/off
    Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
    5) Snooze (SNZ) and Hourly Chime (SIG):
    Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
    To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
    6) Chime on/off
    Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
    Good luck,
    Techjoel
    Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    Unwanted alarm
    using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
    Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
    Watches Logo
    103 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
