American Standard 2748.328 Town Square 5' x 42" Air Bath Tub in White Logo
Anonymous Posted on Aug 27, 2010
Hello all, There is a awful sewer smell coming from my bath tub, it leave some type of brownish film over the drain almost up to the spout, it fumes or what ever it is also burns my eyes some, I don't know what it is I have lived here over two years with no problem and this just happened over night, I noticed yesterday that there is a smell coming from my water heater as well, my tub is the only thing having the problem everything else is just fine, toilet, sinks water hoses, is this hazardes for our health, what should I do? my land lord is kinda tight so i want to try to figure this out on my own if I can, can anybody please help me. Worried Mom
  • Anonymous Aug 27, 2010
    Thank you very much for your advice, however there is no setic tank and no trees around, does anybody else know what it may be
    Worried Mom
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Aug 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
19
Questions
0
Helped
8560
Points
27
Sounds like a septic back-up...if indeed you have a septic tank. This could happen very easily--just from flushing a tampon or cigarette ****. Also certain types of trees have a rapidly growing root system that does nothing but head for the nearest water source, growing and entwining into a septic tank, clogging it up.
If this is the case, call a plumber to get it unclogged, then get some root kill and enzymes to flush down the toilet every couple of months.
1helpful
3answers
How can we get rid of the occasional sewer smell in our house?
When you next get the smell, check the traps to see if there is enough water in there to fill the trap, if one is less then it looks like water is getting sucked out when toilet is flushed or that trap (usually bath or shower) hasn't had water going in (lack of use) and water has partially evaporated.
Sep 06, 2014 • Plumbing
Rotten eggs smell
The smell is sewer gas coming back in the house from the sewer or septic tank ether from a dried out water trap in a floor or fixture drain, or from the roof vent, or a hole or separation in pipe or fitting. Like wax ring under toilet. First pore water down every drain to fill any trap that might have gone dry, then flush toilet or run washer or drain bath tub.This will displace gas in pipe and will cause the smell to increases if there is no smell then the problem is fixed if not check roof vent it may need a charcoal filter on top, There is no water trap on air vent on roof and is an open hole to the sewer or septic, The heating system in the winter or AC in summer will draw the gas inside from the vent.If it is the vent you should be able to smell it from outside. If all tests fails You will need to have a smoke test done. A smoker is set up outside and the line is filled with smoke and will show where gas is coming from. Also it might be a good ideal to check all gas fittings in case it is a gas leak.
Jun 15, 2014 • Plumbing
Tub spout diverter
Check the basement. There may be a valve (two valves) that someone partially closed in the past to limit how much water was used for a bath.
Dec 21, 2013 • Plumbing
Washing machine sewer odor
The drain pipe that your drain hose goes into is more than likely the problem. The drain pipes should have a p trap which looks kind of like an S- shape the water stays in the trap preventing the smell from backing into your home . If there is none, install one.
My Kenmore smells like sewer. What could be the problem?
The problem is mildew that is on the outer tub (the one that surrounds the metal tub that you can see). There has been much written and discussed about this. I have a Whirlpool that smells awful if we don't leave the lid up and a fan on it. Whirlpool makes a product that will abate the smell somewhat, but the smell comes back and the product isn't cheap.
I have had temporary success with bleach or Lysol (the good old fashioned disinfectant in a brown bottle) but you have to douse the tub from top to bottom. Be careful with allowing bleach to remain in a washing machine as it will corrode all metal parts inside the unit.
I wish I had an easy answer for you. Prior to this washer, I had a GE washer for over 30 years that never, ever smelled bad. I want it back.
Good luck from Detroit, MI.
2answers
When do you need to vent a bathroom sink?
You always need to vent a sink. If you do not vent the sink it will create a vacume and **** water, or air from the nearest fixture.. example, if you connect to the sewer line near a bath tub, when you run the sink water it will **** air from the bath tub drain. If it sucks a lot of air, you will smell the sewer odor since the water is no longer blocking it.
If you cannot run the vent to the roof, there is an in wall vent valve called a studor vent that may work. Get with someone at Lowes or Home depot to show you one.
Feb 09, 2011 • Home
2answers
Have a terrible smell coming out of my tub drain
I hope you put trap back on,or you need to fill trap with water--that is the water seal for sewer gas
1helpful
This might be a plumbing problem but it only happens when I do a load of washing. When the water drains it goes into a pipe in the wall and then my bath tub fills up, and the bath drains .When the water...
Check your main vent line for obstructions (animals, nests, leaves, etc.) and then have your drains inspected. There is likely a "log-jam" (pun intended) in the sewer drain line - as it is not allowing the water to drain as fast as the washer pumps it out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
When I run water through this tub spout (diverter in down position) I still have water leaking from the showerhead. I have seen water from a tub spout when the shower is on, but not the other way around....
After you turn water off in about 30 secs pull the diverter up and leave for a few minutes This should allow the water left in shower piipe to drain out the spigot
Sewer gas smell from tub.
Something was flushed that should not have been flushed
You will have to have your drain snaked out.
Top American Standard Home Experts
john h
Mike Cairns
Mike Cairns
deton8 von Splosion
Are you an American Standard Home Expert? Answer questions, earn points and help others
