Question about Fellowes Powershred 480 Shredder
Fellowes Powershred C-480C does nothing. All LEDS blink once on power up then middle 3 LEDS on Sheet Capacitor Indicator blink on & off. No other lights on. No response from any keys. Motor, gears, chain and cutting blades all move freely by hand. Auto Start sensors cleaned, SafeSense over-ride on - nothing. Door open LED will lite when door opened but bin-full does not lite when its switch is tripped. ~Rick
fellowesrep
  • 102 Answers
SOURCE: Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Posted on Mar 10, 2008
  • 215 Answers
SOURCE: The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Posted on Apr 15, 2009
  • 32 Answers
SOURCE: Fellowes PowerShred PS 40 with defective switch
Its just seated together with the gear/blades housing ,
make sure you didnt miss one screw, then pry and pull upward its just stuck as the gear housing and blades are pressed in and seat firmly making it seem like its stuck , over time all that paper goo is also binding it up .
Heres a few sites that have gears another that has manuals you may have to call or email as not all parts are listed on website
http://www.compax.com/shredders/parts.html
http://wheelermachines.com/manufacturer.html
http://www.manualsonline.com/ex/thread/view/idThread/1735067
Posted on Sep 01, 2009
FixinFax
  • 3085 Answers
SOURCE: Looking for a manual on a Fellowes 220 Powershred
There are no spare manuals or parts,
Blow canned air down into the feed slot, then lube with Marvel Oil generously..
Posted on Oct 23, 2009
  • 250 Answers
SOURCE: shredder will shred about 3/4 of a sheet of paper
If your shredder has a feature where it won't run with the door open/shredder off the bin, you probably need to make sure that the safety is engaging properly. If the motor seems to sound very labored when it runs, unplug it, and check the blades to make sure there's not a lot of extra stuck in them. You may need to clean them and lubricate it with special shredder oil ONLY.
Posted on Nov 25, 2009
Fellowes c-480c squealing noise
Shredders get incredibly dirty with paper dust. There is also a lubricant that you are supposed to put on the blades. There is a basic guide here:
Mar 13, 2015 | Fellowes Manufacturing Powershred C-480C...
HOW DO I MAKE A FELLOWES C-480C SHREDDER PUMP OIL
Hi Wendy, push and hold down the "bulldog" button and then hold down the "forward" button. You should hear the pump pumping oil. May take15 seconds before you hear a hum. If you do not hear anything, the pump may have to be replaced. Clogged oil nozzles or tubes could also cause a problem. This is a common problem and Fellowes re-engineered several components to fix this problem. You can google Fellowes to get a phone # to find an authorized service center. good luck.
Nov 20, 2014 | Fellowes Powershred 480 Shredder
How can I buy a replacement guard strip?
I do not know it you can or not. Below is a link to the manual; look for your model and down load it. It might be of some help to you, Good Luck.
Fellowes Shredder Manuals
Oct 08, 2014 | Fellowes Products - Powershred Shredder...
Safesense led continues to blink when power on
Below is the manual for your shredder. Does the shredder still work even though the LED blinks?
Sep 19, 2014 | Fellowes Products - Powershred P-58CS...
SAFESENSE ISN'T WORKING ON C-480C FELLOWES
Use a cotton bud dipped in alcohol and clean sensors
Run shredder once a day in reverse for 15 seconds to clear cutters
Empty wastebasket when bin full indicator light is illuminated using b0
If this does not solve the problem goto
www.fellowes.com for an extensive on-line support section
Feb 27, 2014 | Fellowes Manufacturing Powershred C-480C...
Squealing noise when shredding
Have you tried putting any shredder oil on a piece of paper and running that through the shredder?
Feb 03, 2014 | Fellowes Manufacturing Powershred C-480C...
Fellowes Powershred PS 60CC stopped working
I own a Fellowes PS 60 shredder.
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Jan 14, 2010 | Fellowes Powershred PS-60 Shredder
Full bin light is always on!
On most shredders the full bin sensor is actuated with a plate just under the cutter head. When the bin gets full the paper builds up and pushes the plate back.
Be sure to unplug main power before during any service.
Try wiggling the plate back and forth to clear out any backed up paper.
Jun 04, 2009 | Fellowes Manufacturing Powershred C-480C...
Fellowes Powershred 480 Shredder Logo
78 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
