Question about Vacuums
Describe your Eureka 5740A Litespeed Bagless Problem It picks up dirt and spits dirt bag out
  • 98 Answers
You have a clog in the hose pull the hose and unclog it
Posted on Aug 27, 2010
Eureka Model Whirlwind litespeed. The rotart brush does not turn or rotate. Should it turn or rotate in order to give better suction?
Hello fnintel, yes, if you are using the upright vacuum it should spin, ( the belt likely slipped off, or the brush is clogged with hair and the likes.)
However, if you are using the hose on the vacuum like a shop vac, some models bypass the rotary brush.
Jan 09, 2011 | Eureka Whirlwind Litespeed 5840 Bagless...
Poor suction not picking up dirt from floor
Most likely your brush needs to be removed and cleaned or the belt is broken for the beater brush. Clean all debris that might be in the bristles of the brush. You will see a holder for the brush on each end that holds it into the frame of the vacuum. The two holders should turn freely. If they do not, spray a bit of WD40 between the brush and the holders and rotate the holders around the brush. Also replace the belt if necessary. Doing this will clear up the most common occurring cause of the problem you are facing.
Good luck and feel free to contact me if you find this does not solve your problem.
Paul
Sep 19, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
How do I replace the belt on my mom's Eureka Whirlwind litespeed 12 amp 15" ?
take the cover off from the bottom there should be clips or screws on the bottom.and work the old belt off and new one on
Aug 12, 2010 | Eureka Whirlwind Litespeed 5740 Bagless...
The vacuum roller won't turn but the belt is fine Eureka Whirlwind Litespeed
The belt may look fine but it's probably stretched out. Rubber belts are usually good for about 1 year. The tension of the belt is what allows it to turn under the strain of the carpet. Make sure the brushroll spins freely when held out of the machine. Eureka brushrolls are prone to melt down on the end caps. If that has happened you will need a new one.
May 01, 2010 | Eureka Whirlwind Litespeed 5840 Bagless...
New vacuum doesn't pick up....
bockage on the pipe bend.open and clean out.
Jul 19, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
My Eureka Lite speed whirlwind has a bad odor when it runs.
It is either the filter or on the roller or belt.
  1. Eureka Parts Storewww.Eurekapartstore.com Unbeatable prices on Eureka Parts Largest site for Eureka parts.
  2. Eureka Partswww.ThinkVacuums.com/Eureka Eureka Central Vacuum Accessories Find Hoses, Tools, Nozzles & More! Google Checkout
  3. Eureka Part Storewww.vacuums24x7.com/Eureka-Parts Bags, Belts, Filters, Repair Parts. Complete Selection Eureka Parts.
Jul 06, 2009 | Eureka WhirlWind Litespeed 5844 Upright...
Eureka altima 2993av bagless
Hi
Sounds like its blocked. Check under the glide plate and the hose. Look in the book for model specific details
Feb 22, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Dirt Devil Featherlite not picking up
It sounds like you have a blockage somewhere. The brush roll will still gather material, but if the suction is insufficient, it will spit it back out eventually. Take the bag out and check at the connection for blockage. When you are sure it's clear, put in a new bag and turn the machine on. The bag should inflate rapidly. If it does not, check elswhere for blockage.
Jan 19, 2008 | Dirt Devil M088905 Vision Bagless Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
