Question about Home
I have single lever Moen kitchen faucet with one hole sprayer on the side. Unit is about 14 years old. The other day we noticed driplets of water seeming to come from where the hot water supply connects into the faucet. I don't know if that's the true source of the water, because, depending upon the position of the spout, sometimes we see driplet running from under the spout onto the escutcheon and into the sink. Any suggestions?
    Problem Solver:
  • 7 Answers
It's a Moen and has a lifetime warranty I believe. Return for a new one.
Posted on Aug 27, 2010
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have a Moen single lever faucet. There is low water pressure coming from the faucet, Can anything inside the faucet be replaced to increase the water pressure? Thanks Bob Fruhling
I have had the cartridge replaced in my moen single handle faucet with sprayer in the end and now it turns off by itself. Any suggestions on the problem
Aug 15, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Moen kitchen sink faucet side sprayer is stuck on
We had this same problem. We twisted off the sprayer cap to access the diverter valve under the trigger. The nylon diverter was stuck down into the cavity and was not popping out when the trigger was released. We pushed it down several times with needle nosed pliers to release it then applied a drop of household oil lubricant with the valve pushed all the way in. Then pushed and released several times to work the lubricant around the sides of the valve. After re-assembly, the sprayer seems to work perfectly again.
May 29, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
We are trying to replace our Moen Adler Faucet and we need to know how to remove it.
first off swhut the water off under the sink,if no shut off valves under the sink then shut the main water valve off.next turn the old faucet on to make sure water is off.now get a light and look up and behind the underneath side of sink,disconnect the water supply lines now way up high there is 2 threaded tubes undo the nuts and the old unit will come out.
Jan 11, 2010 | Porter Cable Moen Legend, Single-Handle...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
