Question about Acer Aspire 5610-4648 Notebook
Tengo una laptop acer extensa 4630z y no puedo activar su camara ni el bluetooh ayudaa porfaa!
5 Suggested Answers
the terrier
  • 94 Answers
SOURCE: I need DVD System Recover Laptop Acer Aspire 5920-6168
hi techpa
you may find it here http:\\global.acer.com/support/downlowds.htm
Posted on Oct 26, 2008
  • 52 Answers
SOURCE: acer extensa 4630z windows complete restore
I wrote to Acer myself about this and this is their reply.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
kornho
  • 781 Answers
SOURCE: tengo una asus y no puedo escribir la letra enie.
para que pueda meter caracteres con la combinacion alt - (numero) tiene que utilizar el key pad numerico,
en un laptop para poder utilizar el keypad numerico (letras: u, i, o ; j, k, l; m, <, >) necesita utilizar la tecla "fn" y la tecla funcion que activa el key pad numerico (en mi caso es la tecla f11), en su caso puede ser diferente, mire los symbolos en las teclas de funcion, hay un simbolo que asemeja en teclado numerico diminuto.
por ejemplo para meter la letra "ñ" presione lo sigue
1. active el keypad numerico tecleando una vez y simultaneamente "fn" y f11 (o la tecla que active esta funcion en su teclado).
2. ahora si teclee alt y manteniendo presionado alt, teclee uno a uno las teclas j, o, u las cuales ya deben estar activas como numeros 1, 6, 4 respectivamente.
Posted on Apr 11, 2010
SOURCE: ACER ASPIRE 5100
Desconecta la bateria principal y Desolda una bateria chiquita que trae en la tarjeta madre (Posiblemente este debajo de la tarjeta Inalambrica).
Luego manten precionado el boton de encendido durante unos 10 segundos. Luego conecta todo y Listo. Ya que compruebes que te da Video le soldas nuevamente la bateria. Eso es Todo
Posted on Jan 31, 2013
Tengo problemas, con mi portatil VAIO VGN-FJ170 no puedo encontrar los controladores de video y camara motion eye. Por favor alguien puede ayudarme. Gracias
use el software system restore . vaya al panel de control.Use the system restore a una fecha que usted sabe que estaba trabajando, y reparelo.
Si esto no resuel el problema, haga update driver de su suplidor de su computadora, Desintale el viejo driver corrupto e instale el nuevo. y trate de nuevo.
God bless you
May 23, 2013 | Sony VAIO VGN-FJ170/B Notebook
Como puedo.desbloquear mi skout
Como puedo recuperar mi cuenta en SKOUT si le di mal uso como lo recupero porfa digame
Jun 04, 2012 | Sony GPS
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Tengo una asus y no puedo escribir la letra enie.
Apr 11, 2010 | ASUS Eee PC 900 Notebook
Instalacion autolamp
Si la version de tu camioneta es canadiense, no debes tener problema (yo tengo una), las luces se supone deberian prender solas, en caso de ser una version estadounidense debes buscar algun electrico que te instale el aditamento despues de adquirirlo digamos en un yonke (no debe salir caro) de otra manera podrias adaptarle "velas" a tus faros para que prendan de manera permanente mediante la instalacion de "focos de pellizco", es una solucion facil y barata ya que tus faros son de plastico.
Mar 02, 2009 | 1996 Mercury Villager
Necesito ayuda .......
tengo una camara web marca cap y no tengo elo cd con el driver el codigo de la cam 49152-DM
Jul 23, 2008 | Computers & Internet
Necesito todos los drivers asignados para el Acer TravelMate 3010 (3012WTMi)
https://www.acer.com/ac/en/US/content/support for drivers and support
Mar 07, 2017 | Acer Cameras
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Acer Aspire 5610-4648 Notebook Logo
47 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
