Question about Whirlpool GC3NHAXVY Stainless Steel Side by Side Refrigerator
Ice maker is not producing ice - Whirlpool GC3NHAXVY Stainless Steel Side by Side Refrigerator
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Ice maker did not produce ice, then it started to
    heatman101
    Aug 24, 2010 | Amana ARB2557CW / ARB2557CB / ARB2557CC...
    Ice maker will not produce ice, no water flowing to dipenser.
    Sounds like the water filter is plugged up...
    Here are some basic tips for ice maker troubleshooting2_bing.gif...
    http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
    heatman101
    Jul 11, 2010 | Whirlpool Refrigerators
    Ice maker not making ice. do have water, no ice
    The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
    The ice maker has completely stopped producing ice
    The ice maker is producing ice poorly
    The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
    The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
    First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
    Aug 29, 2009 | Kenmore Refrigerators
    Replaced icemaker with new one but still not working
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs
    Apr 01, 2009 | Kenmore 57029 Side by Side Refrigerator
    LG refrigerator french door icemaker not working
    There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
    Jan 16, 2009 | LG LRFC25750 Refrigerator French Door
    I just changed the water filter and in my fridge and now my ice maker had no water flowing to it.
    Jan 06, 2009 | Refrigerators
    Ice maker won't quit dispensing ice cubes don't have ice skates!
    Dec 11, 2008 | Amana Refrigerators
    Ice maker stop making ice for kenmore 106.56352500
    Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
    Ice maker not making ice refrig.model#gsc23kswc ss
    Check the following suggestions from repairclinic:
    Oct 10, 2008 | GE Refrigerators
    Whirlpool GC3NHAXVY Stainless Steel Side by Side Refrigerator Logo
    21 people viewed this question
    Top Whirlpool Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
