Question about Whirlpool Calypso GVW9959K Top Load Washer
My washer will not drain. The washer at first was giving several errors like LF so we had the pide snaked to see if that was the problem. Now the washer does not give an error but just fills up and does not drain.
  • Whirlpool Master
  • 8,220 Answers
The pump is electric. It ain't too hard to replace. Take that emblem off the front and remove the screw under it. Slide the top forward and then raise it up. Get the front panel off and remove the drain hose. Get the tub out and flip the tub over. my washer will not drain.  The washer at first was - 60ebd71.jpg6a54e89.jpg
Posted on Aug 27, 2010
  • Dan Webster
    Dan Webster Aug 27, 2010
    The washer tub is suspended on 4 rods. Unplug the harness to the motor and pump and release the bottom of each rod then tip out the tub. This summer My friend Robert and I worked on one of the older models. Took some photos: Calypso Revamp
Whirlpool washing machine with error code FL
Dos your machine sometimes continue to fill Fl could be LF I have seen the codes pop up different than the tech sheet anyway LF is a long fill wish I could tell you the exact location of the service manual WP always moves it try on the inside of the bottom panel first if not there look inside might be mounted on wall a few times located under top panel read it it will explain how to place machine into diagnostic usually on LF the unit is draining slow or the black hose that leads to the pressure switch has popped loose a rubbed against basket pulley causing a small hole in the rubber this will give a LF error hope this helps
Feb 13, 2015 | Whirlpool Duet WFW9250WW 4.0 Cu. Ft. Front...
Kenmore elite oasis model 110.27032600 LF error. had an issue with the washer cycling through all the lights, would turn it self on etc. Had the repair man come out and he replaced the computer board....
The LF error means Long Fill.
When you start a cycle the water should come into the dispensers. If you have a good flow through the dispenser the valves will be okay.
I recommend checking the inlet water screens on the back of the washer. The inlet screens are located on the water valve. To access the screens you will turn the water off and remove the inlet hoses. The screens prevent debris from entering the valve and sometimes over time mineral deposits build up on the screens. This can block the water or slow the water fills down to a trickle. You can pull the screens out and clean them if necessary. Flush the inlets thoroughly with water when replacing the screens. If debris gets past the screens, it can cause the valves to stick open and an overflow of water can result.
While you have the fill hoses disconnected, place the ends of the hoses in a bucket and briefly turn on the faucets to check for proper water pressure and flow from both hoses.
A common reason for an L F (long fill) error on this washer is the drain hose being stuck to far down the drain standpipe.
If the drain hose is to far down the standpipe then a siphon can occur which causes the washer to fill and drain at the same time. This will cause a long fill error.
Feb 02, 2011 | Kenmore Oasis HE 27082 Top Load Washer
My washer will not drain. At first it was giving the normal error messages like LF, so we had the drain piped to see if it was clogged. Now the washer fills up and does not drain. I have a Whirlpool...
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 27, 2010 | Whirlpool Washing Machines
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer will start cycle then stop and LF starts blinking on the screen
From the owner's manual:
"LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite model #110 27082601
In reference to the LF error code on your Kenmore Washer
When your washer displays error LF , it is due to low water pressure, slow or continuous fill.All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems;
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine isn't supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house
* Error Codes- LF for long fill or FH for no water detected.
o A plumber may need to be consulted if the pressure is found to be too low.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
