Question about The Companion Group Companion 32 amp Jig Saw JS55CN
HOW DO I REMOVE THE BLADE ON A JIG SAW JS55CN (BENCHTOP PRO) FRED 55FRED@SBCGLOBAL.NET
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
How do you change the blade on a Benchtop Pro Compound Miter Saw?
somewhere on the motor of the saw but near the blade housing there is going to be a button or small metal lever that you psh in and hold while you loosen the blade, BE SURE THE SAW IS UNPLUGGED!!! you may have to turn the blade slowly with your hand while pushing the blade lock button to find a locking point on it, once you get it locked you should be able to loosen the blade, when you take it off be sure to note which way the washer on the bolt is facing so you can put it back correctly, you will also have to hold the blade lock to tighten new blade, hopes this gets you going
Jan 23, 2011 | Garden
How do I change the blade on a jig saw
on most newer jigsaws there should be a collar that you just slide back to remove old blade and insert new one
Oct 08, 2010 | Black & Decker Scroll Jig Saw Blade
How do i change the blade
Hello. where the blade enters the blade holder there is a screw. Unscrew it, turn counterclockwise, remove the screw and then remove the blade. Reinstall the new one and replace the screw. Joe
May 08, 2010 | Bosch 1581AVSK Top Handle Jig Saw Kit
I want to remove the blade (Jig Saw 1587 AVS
there should be a botton or thumb press undernith up frount unplug and depress and blade will come out
Apr 09, 2010 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
Blade stuck in makita 4351 jig saw cant remove
Take the set screw that holds the blade all the way out.
Then take a ice pick or small flathead screewdriver and work the broken blade out.
Oct 24, 2009 | Makita 4351FCT Barrel Grip Jig Saw with...
Task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Aug 04, 2009 | Saws
The Companion Group Companion 32 amp Jig Saw  JS55CN Logo
355 people viewed this question
Top The Companion Group Saws Experts
Tom Chichester
ray gallant
Are you a The Companion Group Saw Expert? Answer questions, earn points and help others
