Question about Haier HSE04WNA Compact Refrigerator
Whenever I turn on my fridge it sounds like it is releasing gas and there is a funky smell in the fridge. I think it may be leaking some chemical but I cannot find the source of the leak anywhere.
  • Haier Master
  • 17,130 Answers
If you have noticed this leak then this will be best seen when it starts cold. So shut it down and after removing all food from inside , restart and feel/listen/smell for the leak.
If you notice this slight smell coming from the cooling coils inthe freezer section, then do not waste time but shut it down.
You will need to remoe gas off by pumping , then the system be pressurised and checked for leak.
Get help with the equipments to check /estimate/confirm forr you to decide.
But always try to get a warranty on work if there is high estimate but decide with the cost of a new one. j
Posted on Aug 27, 2010
Why does my fridge and freezer have a chemical smell?
What might cause a chemical smell coming from a ... - Ask.com
www.ask.com > Home & Garden > Appliances > Refrigerators & Freezers
Coolant leaks and the use of chemical based cleaners are common causes of achemical smell in the refrigerator. Immediate action is necessary if the cause of
Jul 27, 2015 | Frigidaire Refrigerators
We have a funky smell when we turned on the rce606tra11 one morning last week and it has not stopped. It seems like a petroleum smell (strong). Had a serviceman look a the unit could no find anythin
It sounds like a gas leak! Spray all of the connections with Windex. If you get any bubbles, that's a leak. Tighten it. But...I can't believe that a bonafide serviceman wouldn't think of that.
Dec 12, 2014 | Rinnai Heating & Cooling
Chemical smell in refrigerator and freezer.
Make sure that you switch off and remove all the items from the fridge. Now confrim if the fridge is from any food stuff or from the fridge. It sould be from any electrical burning, like the fan, the heater, the lamp holders etc. to even gas leak or compressor oil. If you are confirmed on the smell it is important to shut off and take help to repair as it may be hazardous. so check this out. Good day
Aug 10, 2010 | KitchenAid Refrigerators
wipe it out with a clorine bleach solution,leave the door ajar to gas off and use a syringe to blow out the drain hole.wipe dry then cover any open topped food containers with cling film.as all fridge/freezers work best when 3/4 full.use empty airtight boxes to fill any spaces,she/he will notice a big difference in lower running costs...
whilst the freezer may be frost free, the fridge is not, so expect condensation to form on any gloss surfaces...(the more airspace the more condensation........)
Jul 26, 2010 | Sub-Zero 695/S Side by Side Refrigerator
Pervasive chemical odor
I was just recently having this problem myself (and I'd also encountered it long ago as well). Fortunately, I live in an apt. for the time being, so it was exchanged with another fridge after persistent complaints to the management. However, I did do a little sleuthing before the exchange ... and I did read something online where someone said (and pretty definitively too) that oftentimes "chemical smells" occur as a result of a coolant leak. Despite the fact that I did not physically see a leak, this explanation still made the most sense to me given the character of the smell.
So, your problem, like mine, is more than likely caused by an internal, occult leak. Also, not to worry you, but I would advise you not to consume anything else from your fridge/freezer until this is resolved since your food is being constantly permeated with this noxious gas circulating around it (and yes, even through the containers' small crevices). I ended up pretty much throwing out everything :( I am an RN, BSN by the way - we nurses usually have some pretty sound advice (even when it's bad - sorry).
Apr 28, 2009 | Kenmore Refrigerators
Fridge smell
check the pipes at the back of the fridge, it could be that one of the pipes has a crack and is leaking gas or oil. If not check the inside of the fride for a brown oily residue. This indicates a leak. Don't turn the fridge back on becasue if the oil and gas mix then the fridge will no longer be usable. If you find either of these get an engineer to fix the problem.
Oct 25, 2008 | Frigidaire FRS26R4A Side by Side...
Chemical odor
Hi serena38,
I'm Harvey the Master Plumber.
Your question is: You have a sweet chemical odor in our boat cabin, it leaves a sweet taste in your mouth. You cannot find the source. The fridge does not work. You can smell the odor stronger when the A/C is turned on or when the boat is closed up with the A/C off. Help????
Great, I live on a boat! I can think of two reasons for this. The first and most likly is electrical. Look carefully at the components especially the capaciter, it's on or near the motor. If it is leaking or out gassing, replace it. Wire corrosion can cause a wire to slowly give off fumes. These kinds of problems are common on a boat so look very carefully i.e. testing meter is helpfull here. I've already expirienced this and it sure was hard to find. Less likely is a freon leak. You won't smell the freon itself but if the oil is a little burnt, that can be smelly indeed. You will need a special leak detector for that. Anyway my money is on the electrical.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
May 21, 2008 | Hotpoint HSS25GFP Side by Side...
My amp is turning on but!!!
you probably blew it up. Whenever you smell that smell it is almost always a capacitor in there that blew.
Jun 17, 2007 | Kenwood Excelon KAC-X521 Car Audio...
Haier HSE04WNA Compact Refrigerator Logo
147 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
