Question about Sharp AR-5316 Advanced Digital Imager Copier
My copier AR 200 is showing code L6 - Sharp AR-5316 Advanced Digital Imager Copier
  • 61 Answers
Polygon motor lock. Enter clear key - interupt key - 0 key - interupt key. Enter sim 14 copy key. reset the copier if the code returns you will need a tech to check/replace the LSU unit.
Posted on Aug 27, 2010
  • 52 Answers
Low current or DC BOARD PROBLEM
4 Suggested Answers
marsrover
  • 682 Answers
SOURCE: showing L6
dear friend:-you can check what is wrong in the movement of optical system .is there any foreign object stuck the movement-is lenses and optical system cover installed in a right way-try to remove the cover and reinstallit.-check lens home position detector connector.
Posted on Feb 23, 2008
  • 14 Answers
SOURCE: AR200 with L6 fault
Your laser unit may be bad. try c interupt 0 interupt,,enter 14 and push start. the machine should reset. If the code returns, you need a laser unit replaced. 200-300 dollar repair.
Posted on May 01, 2009
  • 990 Answers
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Posted on Aug 19, 2009
WHAT IS THE L6 CODE
L6 is a motor lock code relating to a paper cassette. There should be a 2 digit code after the L6. Please tell me the model sharp and the 2 digit code and I can help more.
Apr 02, 2015 | Sharp AR-M205 Copier
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
ERROR L6
An L6-10 code is a polygon motor failure in the copier's laser unit. It's what flashes the image to the system drum. If it won't clear after shutting down/unplugging the unit for 30+ seconds then the laser unit (the LSU) needs to be replaced. You'll need to contact a trained Sharp service representative to facilitate the repair.
Oct 01, 2009 | Sharp AR-M205 Copier
Aug 19, 2009 | Sharp AR-M205 Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
AR200 with L6 fault
Feb 04, 2009 | Sharp Office Equipment & Supplies
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Showing L6
Feb 23, 2008 | Sharp AR 163 Copier
Sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
107 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
