Question about Oster ODF520 Fry Right Deep Fryer
How much oil do I add to the fryer. is there a fill line
  • 17,130 Answers
The oil depends on the food item you intent to fry and the size and quantity. If there is only few items then use oil to just dip them in soaked but if there is more items to be done , then you can have the to be fried food just having the fully dipped level of oil.
Since the oil which is fried once is never used, it is good to use the least quantity that is needed so as not to waste oil.
Hence there is no specific fill line, but your Logic..
Posted on Aug 27, 2010
I would like to download a manual for the big boss oil-less fryer
PDF]big boss oil-less fryer instructions 12-12-11 - The Home Depot
www.homedepot.com/catalog/.../a5/a5961b72-678c-4b49-b11f-c7af721ad7ad.pdfDec 12, 2011 - Just fill it with your choice of oil. Then spray it lightly over the food prior to cooking (1 to 3 sprays). 3. You can increase the capacity of your BIG BOSSOil-Less Fryer when cooking large foods such as a turkey (up to about 16 lb.).
Big Boss Oil-Less Fryer (1300-watt / 16-Quart) - Hot Air Frying
www.hotairfrying.com > Models of Hot Air Fryers > Countertop Convection OvensRecipe book: small recipe book (additional recipes on fan sites such as http://cookingupthecure.com/category/recipes/big-boss-oilless-fryer/ - link valid as of ... big boss oil less fryer Google Search
Mar 25, 2017 | The Kitchen Appliances - Others
How much oil should i use
Your fryer should have a fill line in the pot that you would use as a guide and not fill beyond that line....It should be at the back wall of the inside pot of the fryer....It's going to be alot lower than you would think, as the oil will bubble up and rise when you drop a basket of frozen product in the hot oil, but you don't want it to come over the top, so use the line inside the pot as your guideline. Also, you can look at the container your oil comes in too. When American Range says a 45 lb fryer, what they mean is it will cook approx 45 lbs of product, that's not 45 lbs of oil.... but it does end up being close anyway. I'd buy 2-3 of the commercial containers of oil, like 20# or so, and use what you need, save the rest.... Susan REO
Dec 12, 2011 | American Range AF45LP Deep Fryer
Cleaning insrtructions
Gp to a restaurant equipment store or a food broker type place, or I can ship the product to you via UPS, but there are prodcuts developed specifically for cleaning fryers out, like Mr. Muscle, Degreaser, etc. You would fill your fryer up w/water, add the solution, like a packet of Mr. Muscle, and continue to boil the mixture for some time in the fryer.... After it's boiled for some time, use a fryer brush on your heating elements, etc, which you can also buy at a local store or I can ship one to you. When the fryer is clean, you will drain the mixture out and rinse several times. You want to make sure you get all the soap residue out of the fryer or it will destroy your oil after you add it in and try to cook with it...Rinse several times, then add your oil and you should be ready to go. You can also drop your fryer baskets in the mixture just like you are cooking and the boil out product will clean them too.. Be sure to drop them again as you rinse the whole unit out.. Hope this helps. Buy a couple of green pads too, and they should help you with any outside baked on stuff
Good luck,
Susan
REO
I just need to know how to completly clean the bottom of my imperial fryer
Are you talking about the actual burners? They make a L shaped brush that you can use to get around the burners themselves, and a quick tip is to clean the fryer warm.... Once you heat up a griddle or fryer, the cleaning gets substantially easier. They also make either liquid or dry powder cleaning additives, which also help with the cleaning... Once cleaned, make sure you rinse all the soap residue out of the frypot, as that will help to quickly break down your oil, once that new oil is heated up. Another tip is to ony turn the temperature up to 325, not 350, as that also helps to break down your oil. Keep in mind, no matter what yu do, your fryer will never look clean again.... Even the clean, used ones look alittle used after some use and never look shiny new again. If you need any of the cleaning solutions, I do sell them and would be happy to ship some to you... Our individual packets of liquid Mr. Muscle cleaning solutions run $1.95 each and for a 30-40 lb fryer, you need two per cleaning. The directions says to drain oil out and rinse to clean out loose soils, fill w/'water to oil fill line, and get water boiling. You add the Mr. Muscle while filling w/water.... Boil at about 225 temperature for 10-30 minutes. (225 degrees keeps it from boiling over). While it's boiling, gently use a fryer brush or scraper to remove baked on soils. You can also buy the powder version, which is $11.95 for a 9lb jug... Fryer brushes are $24.95 and can withstand alittle of the high heat.... I stock all of these items and can ship to you, if desired. Try this anyway, whereever you end up buying your products and this should work for you...This is how we clean the dirty deep fryers we get in and we've never had any trouble. Our phone number is 888-542-5959, and we are Restaurant Equipment Outlet, Cincinnati, Ohio. We sell new/used equipment, furniture, smallwares, just about anything you need for a food service business.
Thanks, Susan
Jul 18, 2011 | Imperial IFS40 Deep Fryer
Hello, my Breville deep fryer has suddenly powered off because I moved it. What is the matter, please?
Some deep fryers have a magnetic quick release on the power cord. First, check to see if the power cord is securely fastened at the wall and at the base of the fryer.
Safety features of deep fryers include auto shut-off when oil overflows or reaches a certain vertical point in the fryer, or if there is too much or not enough oil. Drain the entire fryer and slowly refill it to the maximum fill line.
Some outlets, especially in bathroom and kitchen areas, have GFI (Ground Fault Interrupt) circuits which detect overload or short situations and shut off. You can see an example here. Ensure the "reset" button is pressed down. Another cause could be a tripped circuit breaker. Check the circuit breakers to ensure all of them are in the "on" position.
Mar 09, 2011 | Breville Kitchen Appliances - Others
Our staff cleaned the fryer last night and left the pilot on without filling the oil. . The fryer was with no oil and pilot on overnight. Will it lead to problems or we have to take corrective action.
If the main burners didn't light there shouldn't be a problem. If the main burners came on there could be some damage to the tank but there is no corrective action that can be taken. If damage was done it will usually leak cooking oil when filled. Was the gas valve turned to "pilot" or "on"?
Dec 12, 2010 | Pitco Frialator SG14 Deep Fryer
Just wandering how much oil to put in the 30 quart pot
thanks, all i did was put water in the the pot, took a three liter jug and emptied the water into it. it takes about nine liters , thanks again. jack
Dec 29, 2008 | Masterbuilt M30BV Deep Fryer
Presto fry baby
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Dec 12, 2008 | Presto 05430 FryBaby Deep Fryer
Left my instruction book at home in NC
The formula for calculating turkey cooking time is 3 minutes per pound, then add 5 minutes to total cooking time, rounding to nearest minute: 13.86 lbs. x 3 mins           41.58 mins Plus 5 minutes                + 5.00 mins                                       =46.58 mins Total cooking time             47.00 mins.
Insert cooking thermometer into the deepest part of turkey and make sure an internal temp of 180 F is reached.
Nov 27, 2008 | Masterbuilt 20010306 Deep Fryer
Oster ODF520 Fry Right Deep Fryer Logo
117 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
