Question about GE Refrigerators
GE upright freezer model FUF14DMDRWH. Found most items thawed but still cold. Must have been off for a couple days, maybe longer. Light was still on. Next day, yesterday, it was working again, but seemed to be running a lot. Today motor was off and seemed to be freezing. Just making the gurgling noise. After I opened the door for a bit the motor came on again. Freezer is only 8 years old, but is it telling me it is about to fail completely?
watugot
  • 290 Answers
SOURCE: freezer is cold but not freezing
Do you have a build up of ice in the bottom of freezer? If so, you probably have a clogged defrost drain.
Posted on Oct 06, 2007
Amigaman
  • 248 Answers
Look for frost on back wall of freezer on bottom half. If present it's not defrosting. Number 1 culprit is a defrost heater gone bad. You will have to remove lower cover in rear of freezer section to expose coils. Unplug unit pror to doing this. The defrost heater is at bottom of these coils. It has wires to both sides of it. You will need to check continuity of heater or remove heater and take to appliance store and have them check it. If it's open replace it. Use a hair dryer to remove frost from coils to restore airflow. If heater is ok, problem could be a bad thermistor or a bad board. Let me know how you make out with heater.
Sea Breeze
  • 4654 Answers
SOURCE: GE Upright Freezer problem/door
The door seal is damaged or the hindge alignment have allowed the warm air to enter and the cold air to leak out the of the freezer. Look and feel around the door for the cold air and check the top and bottom hinges to make sure they haven't become loose. Look for tears also around the seal because this will do the same thing. Let me know what you find. JT
Posted on Oct 24, 2007
hotuna
  • 288 Answers
SOURCE: Freezer thawing and refreezing
The freezer is supposed to thaw at least everyday. Only, you usually kant tell because it doesn't do it long enough to melt the food so you don't notice it. You have a couple of components to check here. 1 is the defrost timer, which unless it has been changed recently, has the same pre determined defrost time. So you would have noticed by now. Next is the defrost termination switch. If you have excess ice on the evaporator, this will make the defrost longer than before. Unless the switch is going bad causing the defrost to go extra long, there is an excess amount of ice that is more than usual. Bad door seal will cause this. A slightly low freon charge. And a thermostat that is malfunctioning, causing the freezer to run continuously, will make excess ice buildup in the freezer. I would make sure the kids aren't leaving the door open and the gaskets are good. If not the case, call a repairman.
Posted on Jan 09, 2008
  • 37 Answers
SOURCE: SIDE BY SIDE Frig & freezer
hurlsdad.
Sounds like a noisy evaporator fan. Take the shelves out ot the freezer then take the panels on the back wall of the freezer off. The fan will be there. Then you will know for sure thats the source of the noise. When it is time to replace it...easy fix. (few screws) Here is an excellent source for the part..www.repairclinic.com. My favorite place for appliance parts.
hope this is helpful,
handiman518
Posted on Jan 16, 2008
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
Trying to see if it has a drain plug
FILL 1 or 2 shelves with crumpled up newspaper . The ink in the newspaper , will absorb odor . May take a while , but it's the only proven way I know of , to remove fish odor . May have to change paper every couple of days , till the odor is gone .
Jun 16, 2009 | GE 20.3 cu. ft. / 575 liter Upright...
GE Freezer Not Freezing
I am not an expert, but if the defrost heater is not working, then maybe when it was unpluged the coils didn't completly unthaw. If not, the freezer still will not cool properly.
Mar 25, 2009 | GE 13.7 cu. ft. General Electric Upright...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Jan 18, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Jan 09, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Oct 23, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Refrigerators Logo
114 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
