Question about Xerox Phaser 6130 Laser Printer
Xerox Phaser 6180 print quality has diminished...when printing, faint black streaks can be seen down the length of the page and black/gray areas have fading (not solid color), transfer of black occurs on pages and print crispness is affected.
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
  • 2072 Answers
SOURCE: XEROX PHASER 6180 LASER ERROR
That is a laser fault. You should have a 1 year warranty from Xerox on that product. Call 1-800-835-6100 have your serial number ready.
Posted on Sep 04, 2008
  • 52 Answers
SOURCE: black streaks on printout
Your fuser is worn out. Needs to be replaced.
Posted on Feb 27, 2009
  • 49 Answers
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
Posted on Mar 30, 2009
  • 141 Answers
SOURCE: My xerox phaser 6250 prints the first page fine
Your toner supply route is partially plugged and it can't keep up with the demand. It's not an easy process to clean it but a can of air, toner vac, and an area you don't mind getting dirty are necessary. Pull the imaging unit out and dig around, blowing and vacuuming out toner. Also, pull the black toner cartridge and work through that way as well. If your black toner is low, that might be the problem.
Posted on Aug 04, 2009
Phaser 6180 streaking
If it's just one colour, it's usually THAT colour Toner cartridge that's the cause .
Jun 23, 2014 | Xerox Phaser 6180N Laser Printer
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Phaser 3200 mfp laser printer leaves streaks on paper. First sheet is okay then rest get worst as printing continues.
One of two things.
If the streak is a line. No visible print in the streak, Then most likely the drun cleaning blade is bad and the drum unit will have to be replaced.
If the streaks are sort of reprint. a faint reprint of what is already on the page, then you need to replace the fuser.
Mar 25, 2010 | Xerox Phaser 3200MFP/N Laser Printer
When printing 2 sided sheets our machine puts dark gray streaks on the paper after printing more than 6 pages. The streaks continually get larger until they cover most of the page.
When you are printing 2 sided sheets the reason you are getting streaks, is your first sided not dry yet. I know it is a laser printer, even laser you have waite a bit.
Dec 03, 2009 | Xerox Phaser 7700 Laser Printer
Pages printing blank
Resolving white, light lines or streaks (eliminate light stripes)
From the printer, print the Troubleshooting Print Quality Pages.
With Troubleshooting highlighted, press the OK button.
Scroll to Print Quality Problems by pressing the Up or Down Arrow button. Press OK.
Scroll to Troubleshooting Print Quality Page. Press OK.
Evaluate the Light Stripes Test page for missing printhead jets (missing cyan, magenta, yellow or black color bars).
Clean the maintenance unit's wiper blade and empty the waste tray. A dirty maintenance drawer wiper blade can cause white lines and weak or missing printhead jets. Using a clean lint-free cloth or a paper coffee filter, gently clean the blade with a wiping motion across the entire length of the wiper blade.
Dec 20, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
May 28, 2008 | Xerox Phaser 8400 Laser Printer
Black streaks on printout
Mar 27, 2008 | HP LaserJet 5p Printer
Color Streaks down length of page
My rep advised that if this problem is occuring when using the feeder, the small glass strip to the left of the glass can have some sort of either high lighter or white out stuck to it. He suggests cleaning this with some alcohol.
Jan 09, 2008 | Ricoh Aficio CL2000N Laser Printer
Xerox Phaser 6130 Laser Printer Logo
247 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
