Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
Tape threads but when record button is pushed, it says it is recording in lcd, but time code does not move and I don't hear it engaging. And it will not work in VCR mode. Just get a blue screen.
    Genius:
  • 1,812 Answers
This is most likely caused by a damaged or misaligned video drum and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Sep 03, 2010
  • 53 Answers
Hope I am not so late about it.This type of problem.I will happen in two type.
1 Head is dirty
2.if tape part adjustment is faulty
So check ur drum Hour.
Try to use cleaning tape or try to use new tape some time it solve the problem.If it dose not work then it is a tape part problem.
Posted on Mar 14, 2011
I have Akai gx 230. Its doinf Rew and FF but Play not working, though engages. Tape does not move. Can it be tape threading problem?
Could be either. If you can do some testing, check for power to the capstan motor in play configuration. If there is power at the motor terminals, the motor itself may have failed.
Aug 20, 2016 | Audio Players & Recorders
How to record a cassete tape
Typically, to record on a cassette tape you must press BOTH "Record and Play" buttons at the same time and the tape recorder will begin to record.
Nov 26, 2014 | Audio Players & Recorders
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
My canon camera seems to work fine in record mode. The LCD shows the video and the timestamp, and tape is moving. Yet in playback mode no matter what Tape I use (even if I know the tape has video on it)...
The playback head is dirty. Insert a brand new tape into the drive and perform a record, through the entire tape until it reaches the end. Then play a pre-recorded tape.
Nov 13, 2010 | Canon VIXIA HV30 DV Camcorder
Forgot how to record (dual) tape to tape (been a while)......can not remember sequence of buttons to press or if i need to press buttons at the same time (i.e. Trying to record 1 cassette tape to another...
The left side is usually the playback deck and the right side is the record deck.put in a tape on the left side and push play.Then push the record button first and while holding it down ,the play button on the right side deck.One deck will not have record buttons on it,and that is the playback deck.
Jul 09, 2010 | Audio Players & Recorders
Camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Dec 27, 2009 | RCA CC6363 Camcorder
Marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Jan 05, 2009 | Marantz PM7200 2-Channel Amplifier
Red power light flashes twice and unit will not record. I will not play a tape, none of the tape keys work (rewind, fordward, or pause, etc). I do get a picture in both the vcr and camera mode but the tape...
1. Take out the tape - AND TURN THE CAMERA POWER ON
2. press the menu button (near the viewfinder)
3. Use he wheel on top next to the viewfinderto scroll through the choices
4. Choose "display setup" by pushing the wheel in
5. Choose "C. Rest" by pushing the wheel in
6. Turn camera off
7. Next time you turn camera on y ou should be able to view tapes and record.
IT DID NOT WORK THE FISRT TIME SO I PUT MY FINGER IN TO TRY TO GENTLY PUSH BUTTON WHEN I TOOK THE TAPE OFF AND THEN TRIED SOLUTION ABOVE AGAIN, AND THIS TIME, IT WORKED. BUT PLEASE DONT INSERT YOUR FINGERS IN AS I DID TRY THE SOLUTION 2 OR THREE TIME IT SHOULD BE OK, HOPE THIS WORKS FOR YOU,
THANKS AND CREDIT TO LABBER
Dec 20, 2007 | Panasonic Palmcorder PV-DV53 Mini DV...
User manual for a Bellsouth answering machine model 1188
Found my manual!
To set the time, press and hold the time/code button for 2 seconds. You will hear "TO SET CODE PRESS TIME AND CODE BUTTON."
Release the time/code button.
Press the 2 way/m button once. You will hear "SET DAY AND TIME, SUNDAY"
Press the << or >> button until you hear the correct day.
Press the time/code button once. You will hear "TWELVE"
Press the << or >> button until you hear the correct hour.
Press the time/code button once. You will hear "OH".
Press the << or >> button until you hear the correct minutes.
Press the time/code button once. You will hear "PM".
Press the << or >> button if you need to change to AM.
Press the time/code button once and you will hear the complete time and day setting.
To record an outgoing message, press and hold the ogm button. Release the ogm button and start to record after you hear "PLEASE RECORD AFTER THE TONE" followed by a beep tone. When finished, press the ogm button.
Make sure you put a battery in the answering machine so you don't lose these settings if the power goes out!
Nov 11, 2007 | Lands Phones
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
77 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
