Question about Dell E172FPt 17" TFT LCD Flat Panel Monitor
How do I get the padlock off my screen? I have already reinstalled my operating system.
    President:
  • 670 Answers
You need to press and hold the menu button for 15 seconds and the lock icon will change to an unlock icon.
Posted on Aug 27, 2010
How to fix starting disable saturn relay 2005
Is the car an padlock symbol lit on the instrument cluster ?Or Is there a message in the diriver information center
STARTING DISABLED ?
Starting Disabled
Refer to Throttle Actuator Control (TAC) System Description
Car and padlock symbol
Security: Refer to Content Theft Deterrent (CTD) Description and Operation
Jan 31, 2017 | 2005 Saturn Relay
Tip
How to install Recovery disc on your laptop/computer
Formally, when you purchase a laptop or desktop computer, an operating system disc comes with it. But these days, such disc does not come with most laptop or desktop computer because it is already installed in them which is called recovery disk. This has a great advantage, because if it was on a disc, it will have a scratch and it cannot last forever because it might get lost or damaged. So, having it already installed on your laptop or desktop computer by your computer's manufacturer is a very good idea.
Most people are not aware that this recovery disc is on their laptop or desktop computer. And some might know, but don't know how to use or install it.
A Recovery disk is used to repair windows operating system when it has a virus or when operating system is malfunction. Reinstalling windows with recovery disks helps to recover your computer from any damage.
First, you need to confirm whether your laptop or desktop computer has a recovery disk on it or not. To confirm, click Start Menu, scroll to "My Computer" and click on it. Beside your system's "Local disk (C:)" you should find "RECOVERY (E:)" Click on the recovery disc and you should find a golden padlock with "RECOVERY" in front of this. Also confirm the and make sure it's is a minimum of 6GB.
Now, to install/run your system's recovery disk, go to;"Start menu" > "All Programs" > "Backup & Recovery" > "Recovery Manager". Read and follow instructions and you will definitely perform the recovery successfully.
Lastly, make sure you perform the recovery white your laptop adapter plugged to AC and do not run the recovery on battery. There must not be interruption of any kind in the process of the installation.
Good luck.
on Nov 07, 2010 | Computers & Internet
Can't access user log in page or system restore
i think no other way rather than reinstalling your operating system because you already tried all the methods to repair the windows
while on stuck press ctrl+alt+del to open up task manager if it opens we can try to solve the problem otherwise reinstall it
Post me again
Jun 08, 2012 | Microsoft Windows XP Home Edition with...
On my hp pavilion dv2910us my screen freezes and has horizontal lines going across screen, i have to bend the screen around until it becomes clear. any idea whats causing this???
hi boorad1284
sorry to hear this but this can be two things: this can be your LCD screen causing the prob or it can be an operating system issue (software). to be sure, back up your files then reinstall your OS (operating system). if this is only a software/driver issue, reinstallation of OS will do the trick but if not, it means that this is already your LCD screen or cable causing it.
goodluck!! hope this helps
Sep 27, 2011 | HP Pavilion DV2910US Laptop
I recently reboot my dell and after that my laptop doesn't open but its till open the power but my monitor is all black screen..and it has an icon keep on blink and i think it looks like a...
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Jun 30, 2011 | Computers & Internet
After the boot screen I get a message that says "no bootable devices found"
Try to change your the boot sequence to HDD. If this doesn't change anything you have to reinstall your Operating System. Here is a quick method to reinstall your O.S., but after you reinstall it once:
http://www.fixya.com/support/r4213055-quickly_reinstall_operating_system
If you need further assistance, or have further questions, just leave a comment.
Thank you for using FixYa.
Cheers
Jan 24, 2011 | Dell Inspiron™ B130 PC Notebook
I always have this blue screen of death in my laptop, what will i do?
try to reformat your laptop and always be sure that you have already downloaded drivers for it.
Nov 01, 2010 | Gateway M305CRV Notebook
Dell c400 install Operating system and software
To reinstall Windows XP, perform all the steps in the following sections in the order in which they are listed.
The reinstallation process can take 1 to 2 hours to complete. After you reinstall the operating system, you must also reinstall the device drivers, virus protection program, and other software.
Booting From the Operating System CD Save and close any open files and exit any open programs.
Insert the Operating System CD. Click Exit if Install Windows XP message appears.
Restart the computer.
Press <F12> immediately after the DELL™ logo appears.
If the operating system logo appears, wait until you see the Windows desktop, and then shut down the computer and try again. Press the arrow keys to select CD-ROM, and press <Enter>.
When the Press any key to boot from CD message appears, press any key.
Windows XP Setup
When the Windows XP Setup screen appears, press <Enter> to select To set up Windows now.
Read the information on the Microsoft Windows Licensing Agreement screen, and press <F8> to accept the license agreement.
If your computer already has Windows XP installed and you want to recover your current Windows XP data, type r to select the repair option, and remove the CD.
If you want to install a new copy of Windows XP, press <Esc> to select that option.
Press <Enter> to select the highlighted partition (recommended), and follow the instructions on the screen.
When the Regional and Language Options screen appears, select the settings for your location and clickNext.
Enter your name and organization (optional) in the Personalize Your Software screen, and click Next.
At the Computer Name and Administrator Password window, enter a name for your computer (or accept the one provided) and a password, and click Next.
If the Modem Dialing Information screen appears, enter the requested information and click Next.
Enter the date, time, and time zone in the Date and Time Settings window, and click Next.
If the Networking Settings screen appears, click Typical and click Next.
If you are reinstalling Windows XP Professional and you are prompted to provide further information regarding your network configuration, enter your selections. If you are unsure of your settings, accept the default selections.
When the Welcome to Microsoft screen appears, click Next.
When the How will this computer connect to the Internet? message appears, click Skip.
When the Ready to register with Microsoft? screen appears, select No, not at this time and click Next.
When the Who will use this computer? screen appears, you can enter up to five users.
Click Next.
Click Finish to complete the setup, and remove the CD.
Reinstall the appropriate drivers with the Drivers and Utilities CD.
Reinstall your virus protection software.
Reinstall your programs.
Sep 23, 2010 | Dell Latitude C400 Notebook
Hello When I switch on my Laptop I get a black screen with BOOTMGR is missing press CTRL + ALT DEL to restart, when i do this it just returns to the same, what can i do please help.
If your getting that error message that means your operating system is already corrupted. You just need to reinstall a new operating system. You can contact your computer manufacturer to get an operating system or buy one through microsoft.
Jul 12, 2010 | Toshiba Computers & Internet
When I turn on my T-30 the IBM logo pops up and at the bottom it says F1 to boot up F12 to Boot up Safe Mode Then a white padlock appears in the upper left hand corner of the screen, indicating it is...
That white padlock is a system password lock. Did you recently enable a system password? Try restarting your laptop, pressing F1 or F12 to see if it will let you enter the password, then it should let you boot into the operating system.
Mar 04, 2010 | IBM Computers & Internet
Computers & Internet Logo
126 people viewed this question
Alun Cox
