Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
There's a distinct section on the left hand side of the photos with a different exposure/contrast to the rest. There's a clear line between the two sides running from the top to the bottom. Everything to the left of it appears slightly darker than everything on the right. The camera body is a manufacturer refurbished Rebel T1i from eBay and the lens is a new EF-S 18-135mm.
    Brigadier General:
  • 3,006 Answers
The camera has a sticking shutter assembly. The only cure is to replace the assembly and it's definitely not a DIY job and is not really cost-effective on a 35mm Rebel.
If the body is still under warranty then contact the seller for a refund/exchange.
Posted on Sep 02, 2010
Testimonial: "That would explain why the problem was not apparent in all photos but in most. Thank you very much for your advice!"
Horizontal line with different color exposure above and below line on Canon Rebel t3i
Does this occur only on the camera, or is it visible on your PC during PP operations ?
Mar 25, 2017 | Cameras
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
machine.
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
Photos are not clear and has lines
I have the same problem with my camera. Olympus tech says the lens needs to be replaced at $185+ and it's 18 months old with little use. Not happy, not worth it. Don't buy this camera.
Dec 18, 2009 | Olympus FE-340 Digital Camera
Sharp al1631 copier doesn't work after replacing new drum
Press the following keys in sequence and as fast as possible. Clear, exposure mode (far left key), clear, exposure mode. In other words...clear, far left, clear, far left. The display should go blank if this is done properly. If so then enter 24 as if you were going to make 24 copies, then press print. You should get flashing 000. then enter 7 as if you were making 7 copies, then press print. Should get flashing zero's.
Hit clear a few times and there you go!
Here it is in a line:
"C",far left, "C", far left, 24,print,7,print, CCC or turn machine off then on.
Good Luck
Oct 21, 2009 | Sharp AL 1631 Copier
On my c-765 slow shutter speed
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
May 03, 2009 | Olympus Camedia C-765 Digital Camera
Blurred Images with Olympus E520
Mar 23, 2009 | Olympus Zuiko 70-300mm f/4-5.6 Digital ED...
Lec screen flashing black areas when pictures are played back
Flashig areas show HIGH KEY or HIGHLIGHTS in image, these areas indicate where exposure compensation can be made. They also change to normal function on first magnification point.
Check the manual on highlights also good reading in the histogram section and you will start to understand about contrast and exposure.
Have FUN.
GORDO
Sep 07, 2007 | Nikon D40x Digital Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
57 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
