Question about HP Officejet 7210 All-In-One InkJet Printer
I have Carriage Jam displaying? - HP Officejet 7210 All-In-One InkJet Printer
  • HP Master
  • 4,737 Answers
First try to clean the carriage "Rod" which controls the carriage movement. Use a soft cloth or tissue paper to clean it. You can also the belt that holds the carriage. Try moving it manually, you can push or pull it. After you are done, follow the steps below:
Remove all the cartridges, clean the contact points on the cartridges and on the printer using soft brush/cotton dipped in alcohol/acetone /spirit.
While the cartridges are kept for drying, do the following:
Turn it off > Disconnect usb cable, power cord, inthernet cable; >remove the papers from the tray >open the back panel door (the rear door where you clear paper jam). Also turn off the mains switch which the dc adapter is plugged in. After keeping it Off for about 5 minutes, turn on the printer again with only the power cord connected, keep tapping the cancel button while it boots up and again leave it On for few minutes > turn it off > connect all the cables > again turn it On and keep pressing the power button while it boots up. Now you can install the cartridges. Check the status message. It should work fine now.
If the problem persists, there must be internal hardware/firmware problem and will be needed to call for service.
Good luck.
Thanks for using FixYa.
Posted on Aug 27, 2010
Continuous c5280 "carriage jam" error message
If you already followed these instructions, the last thing to do is to service the printer. I don't know of any self-fix options for this printer. It's worth validating that you've already completed these steps as described.
Carriage Jam or Carriage Blocked Message Displays on the All in One
Apr 21, 2014 | HP Photosmart C5280 Printer
Had paper jam, removed from back of machine, now display says Carriage Jam Open print carriage access door, clear jam and press ok. I have done this and still flashing up the same msg. There isnt...
If the printer thinks it has a Carriage jam, you might want to try removing the ink cartridges and then putting them back. It's possible they got bumped out of place during the paper jam. Hope you can figure it out!
Feb 28, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My hp 7400 displays a message carriage jam
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Sep 20, 2010 | Office Equipment & Supplies
HP 2500CM displays mech carriage jam 415 msg after power on. There is no jam, encoder strip replaced, PCA connectors and ribbon cable okay.
Is the carriage rail clean, and lightly lubricated?
Cheat the door switch and observe the carriage moving at boot up.
(Keep your fingers out of the way!)
See if you can spot where it sticks.
Sometimes the printhead capping unit / service station seizes up, and the carriage cannot leave / return to the home position.
This model was not one of their best.... Good luck
Dec 09, 2009 | HP 2500 CM InkJet Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
My display window says open door. clear carriage jam, and press enter. what is a carriage jam?
A cartridge jam, could be that one of your ink cartridge is not in all the way and causing the carriage to get stuck trying to find "HP". You may try to remove the ink cartridges and close the door / cover and let the printer find home and reinstall the cartridges agian... Good Luck
Aug 17, 2009 | Office Equipment & Supplies
Carriage jam
Usually when the printer displays a carriage jam error the carriage assembly is jamming along the carrige path.
There may be something in the carriage path or the carriage shaft may need lubricating.
Check the area where the carriage is has stoped. There might be an obstruction visible.
Jan 04, 2009 | HP Officejet J5780 All-In-One InkJet...
Carriage Jam Error display on the LCD!
open the lid ,you will see the cartridge track(steel bar) look both end of the track you will find something stuck over there most likely paper chip
Dec 05, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 7210 All-In-One InkJet Printer Logo
29 people viewed this question
Seeker5211
Seeker5211
