Question about Refrigerators
Marvel Ice Maker
I have a Marvel Ice Maker model no. 511MBA1 that will not make Ice. It has a new pump in it and it makes sounds like water is running when you turn it on.
Is there a service manual I could print from online?
    Genius:
  • 1,073 Answers
Check to see if they have a web site or an 800 number
Posted on May 06, 2008
Freestanding marvel ice maker leaks water. is there a universal water overflow pump valve that would stop the overflow of water
just a thought
if you have the room in the container, consider a water level control unit such as is used to cisterns
they are self contained units that are adjustable for the water level required and fit in a space of around 3" dia and about 12" high
Feb 06, 2017 | Marvel Refrigerators
Ice maker not producing any ice and need help
Have you tried turn it off and totally defrosting the unit. Sometimes the ice making mechanism leaks a bit of water where it shouldn't and it just frezes the mecahanism.
Oct 11, 2014 | Marvel Appliance Ice Maker
Ice maker makes hollow ice
Not enough water. Check water filter if you have one and replace. Check water inlet valve pull supply line off of water inlet valve and make sure the screen in the water valve is not stopped up. make sure water line is not kinked.
Jul 11, 2014 | Marvel Appliance Ice Maker
I need to defrost my ice maker. How do I do that?
Marvel usually have an "On" , "Off", and "Clean" selector switch. There are a couple of ways I know of to defrost.
1. Turn the unit off and leave the door wedged open for 24 hours.
2. Get a hose and connect it to another water source, preferably hot water, and melt it off.
Oct 15, 2013 | Marvel Appliance Ice Maker
Will not cool
It can issue with compressor or timer and temp sensor issue.Needs to be tested and faulty part to be replaced.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Marvel 61HK Commercial Beverage Dispenser
Unit turns on and starts to cool. Then runs for about 5 minutes and turns off. Unplug unit and plug back in and it repeats the problem. Will stay running.
It can be issue with temp sensor getting overheated or compressor getting overheated or issue with compressor relay or capacitor.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Our Marvel icemaker was working great then it starting making ice at a much slower pace. It is not make ice no where near as fast as it was. What could be the problem?
Could be a dirty condenser coil, blocked return air, if the ice machine is in a warm environment it takes longer to make ice, water temperature if it is warmer it will take longer to make ice. if water inlet valve is letting water seep buy during freeze cycle it will take longer to freeze.
Dec 17, 2012 | Marvel Appliance Ice Maker
Ice maker works but not water dispenser
Here are the steps I took to fix thi:. First, if you tapped into a copper line near your sink, turn off the off the tap completely and turn it back on again. Why? Occasionally, calcium deposits will build there and cut down your water pressure. You may have enough pressure to run your ice maker, but not enough to push the ice out of the line (I'll talk about this later). Turning the tap on and off breaks up the calcium. This will also fix an ice maker that's slow to make ice or makes hollow cubes.
Next, I just kept running my water pump (about sixty seconds or more at a time) until the water finally started to come through. When it did, a few inch-long pieces of of ice came through -- telling me that the problem was a frozen water line. If running the water pump several times doesn't work (I think it took me six tries), consider turning off your fridge for a while (be sure to remove food and pack in dry ice).
May 05, 2009 | Kenmore Refrigerators
Ice maker not making ice
My ice machine stopped making ice after the city shut off the water line for more than 8 hours. How do I make it start making ice again.
Apr 23, 2008 | Refrigerators
Ice maker won't make ice
The ice maker tells the water valve when to send the water on up. Replace the ice maker! goodluck!!!
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
406 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
