Question about LG LHT854 Theater System
When plug in my exterenal hard drive external hard drive it wont read it, all it says is "searching'
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My external hard drive got a virus had to reformat now computer wont recognize it
I am taking for granted that you are using Windows, not sure which version ( XP , 7, 8 , 8.1 )
and if I am correct, but your computer does not recognize the drive, make sure the usb port is one that will give power to the external drive. You should use USB2 or if available USB3. Those are powered.
Click the Search feature for the particular version of Windows you are running and search for "Disk Management"
Look for the partition of the external drive you are using. It will be given a letter other than C: drive. May be D: E: F: etc etc etc. Sometimes your optic drive is the D: drive, you may need to purchase a program like Everest Ultimate to locate ALL your items on the MOBO.
If your able to find the External in Disk Management, you should be able to format it, rename it, change its functions, etc etc.
Good Luck
Oct 21, 2013 | Toshiba 120GB USB 2.0 Portable External...
Wii wont read the external hard drive
The Wii doesn;t have any built-in capability to read hard drives. You willo need to check with the author of the homebrew program you are using for help.
Mar 19, 2013 | Nintendo Wii Console
My notebook Lenovo no longer reads Toshiba HDDR320E04XW 320 GB USB Hard Drive which earlier functioned correctly.
1. Try to plug in the external hard drive.
2. Goto device manager
2.1. Click Start -> (Right Click on My Computer -> Left Click on Properties-> Click on the Hardware Tab -> Click on Device Manager on Windows XP
2.2 Type "Device Manager" on Start Search (Windows Vista)
2.3 Type "Device Manager" on Search Programs and Files (Windows 7)
3. Click on the Triangle next to Universal Bus Controller
roadfox.png 4. Look for a USB driver says "Unknown" Uninstall it and restart the computer with the external hard drive plugged in and you are all set
Thank you for Choosing
Jul 07, 2011 | Toshiba HDDR320E04XW 320 GB USB Hard Drive
1st time using and confused trying to back up old laptop info to transfer overe to new laptop, i plugged in but didnt do anything
you will need to run files and settings transfer wizard in windows to transfer all the data to your external hard drive, it wont just back it up for you automatically
Mar 10, 2011 | Iomega eGo Portable Hard drive 500 GB ...
Firelite external drive wont read all of new disk
i had a 500 gb pata drive which was read just fine, it's possible that it was just the file system on the drive. if you still have it plug it back in go to disk mgmt and try to format the entire drive with fat32 or exfat, or even ntfs.
Apr 29, 2010 | SmartDisk FireLite 40 GB Hard Drive
I plug my usb external hard drive into my laptop but it does not read. How can I fix it?
Have you tried changing which USB port it's hooked into. If not is there any cd (Drivers/Software) for your external / that it came with?
If not you might have to search for unrecognized hard ware. This will help with that: http://www.techmantras.com/content/finding-drivers-unrecognized-hardware-windows-system
Dec 23, 2009 | SmartDisk FireLite 40 GB Hard Drive
My computer wont read my Simpletech 500gb hardrive
SimpleTech has problems with their controller board. The HDD inside probably still works fine. You might want to get an external chassis and take the hard drive from the SimpleTech and put it into the external chassis. You will need a sata one.
May 07, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
640 GB WD element hard drive has no power
Try it on a different USB port or on a different computer - is this hard drive powered via a mains cable ? If so is that plugged in and switched on as well ?
Also does the hard drive have an on off switch at the back or on it anywhere that needs turning on ?
Does this hard drive have a firewire port or another way of connecting to it ?
Apr 10, 2009 | Western Digital Elements powered by WD 320...
Exterenal harddrive unreadable
Please try it on another computer and see if you get the same results.
Mar 03, 2009 | Toshiba 120GB USB 2.0 Portable External...
Wont read it
hi, if you download hard drive test software from http://www.seagate.com/www/en-us/support/downloads/seatools/ and boot from a floppy disk it will let you know if its a faulty drive and if its repairable.
Happy New Year
John
Dec 13, 2007 | Seagate (ST3300601CB-RK) (ST3300601CBRK)...
LG LHT854 Theater System Logo
71 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
