My 5.1 channel rear speaker not giving loud sound
    Sergeant:
  • 223 Answers
If this is on your computer you should be able to adjust the sound properties/ rear volume in the control panel under sound or audio. often though , rear speakers are suppose to behave this way. they are intended for "wide" and background sounds only when using the true 5.1 Try a movie that has 5.1 sound marked on it. You should be able hear them. Best of luck
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Does my response answer your question? do you need further clarification or help? Please use the solution rating if your problem has been solved, or make a note if your still having trouble.
    Thanks! Gurvy
Speaker leads shorted on right rear channel of Logitech Z-5500 system
First check the speakers by connecting to front connector if thr no sound then replace the speakers.If you here sound while swap the rear amp IC might be damaged replace the IC .
Dec 19, 2011 | Logitech Z-5500 Computer Speakers
No sound loud hum from one channel and no sound from other channel
The audio signal connection between the processor and the amplifier chip is loose or defective. You need to open the tv, follow the wires from the speakers to the amplifier board and then check all the others that plug in there. Fix or replace the faulty part.
Oct 06, 2011 | RCA Scenium HD65W20 65" Rear Projection...
Hello. I need help installing an Eclipse sound system in my Dodge Ram 1500 Quad cab. I went from a Kenwood HU with db Drive 6.5's and 5x7's to the Eclipse CD3200 HU and noticed an immediate improvement...
So you wanna run the subs off of the rear pre amp output rather than just the sub out correct? just get a splitter and run both the rear speakers and sub off of rear channel and front off of front channel. or run all four off of front and subs off rear output. this should give you the sound you want
Nov 04, 2010 | Car Audio & Video
Altec Lansing VS3251 rear left channel not working
Sounds like you "blew" the left channel. Make sure your connections are good, and all positives and negatives hooked up the way they are meant to be. If it still does not work, take it to be repaired. Call around first, with the AND serial number. Get repair estimates, ask about the "bench charge"
Apr 11, 2010 | Altec Lansing VS3251 Speaker
When i watch dvds,the background noise is loud
Go to your set up menu, navigate to speaker set up and check your sound levels to front, center, and rear channels. Adjust as needed to fit the room. My Sony has a test tone option which sends a signal (at levels selected) to each speaker to check sound level and if speaker is connected and in right place.
Dec 28, 2009 | Sony DAV-FX900W System
Rear speakers dont seem to be loud. The front speakers are projecting most of the sound. How do I get the rear speakers to project more sound?
Your settings in the receiver are not set up properly.
You need to adjust the volume output through the rear channels in your receiver.  Review you manual for set up. The issue is in the receiver, not your speakers most likely
Sep 24, 2009 | Coby CSP-94 Speaker
Problem with rear speakers
hello
can sell me the junction box?
thanks
contact brilhasman@clix.pt
urgent
Jun 01, 2009 | Philips Cineos HTS9800W System
Sony STR-DE635, Sound from left surround speaker but not right
first turn the actual volume up on that channel on the reciver then make sure your speaker wires in the rear are using the same lenght each
May 18, 2009 | Sony STR-DE635 Receiver
I can't get surround sound from my theatre system
Read your manual , there is a level setting for each channel as well as a test function. Also remember most media on pro-logic mode dont have to loud sound from the rear speakers. Only a forced mono mode may give you louder sound at the rear. Regards PSP
May 12, 2009 | Audio Players & Recorders
My kenwood receiver has
If you are referring to the rear speakers, it is normal. The rear speakers are not supposed to get a signal as loud as the fronts or center.
A surround sound system was originally developed for playing movies and the rear channels are for effects. In most surround modes the center channel will always be the loudest with the widest range of audio signals.
I have been repairing these type of systems since they have been on the market, so I know a lot about them.
This Kenwood you have is like most surround systems and does not have a feature that you would obviously like to have, 5 channel stereo. Only a few surround systems have this feature and they cost much more than the Kenwood systems. Denon and Marantz both make one with that feature. In 5 channel stereo you get a full signal to all the speakers. All the other surround modes you get a much lower signal to the rear speakers.
So in closing, you do not need it fixed, there is nothing wrong with it. You have a common complaint that many people have who buy a surround sound system but are not fully understanding of just what a surround systems is supposed to be capable of
. This is something that the salesman who sold it to you should have explained to you, that way you could have purchased a system that would have better suited your needs.
I would be happy to give you more help if you would like, just let me know. As I already stated, I have many years of experience with surround sounds systems, in fact I own the exact Kenwood model that you have and I like it very much. It is about the best you can get for that price.
Dave
Aug 22, 2008 | Kenwood VR-505 Receiver
Computers & Internet Logo
David Payne
David Payne
