Question about Xantrex Technology Electronics - Others
HAVE 2 STACKED SW4024S, AFTER TURNING OFF ALL POWER TO WIRE IN MY NEW WATER HEATER, MY #2 INVERTER DOSE'NT WORK AS BEFORE. THE FLOAT LITE WONT BLINK AS IT DID BEFORE, THE LINE TIE & ACI IN GOOD ARE ON. #1 INVERTER IS FUNCTIONING AS BEFORE, LINE TIE & ACI IN GOOD ON WITH FLOAT BLINKING. CAN YOU SOLVE THIS PROBLEM? THANKS, JOHN
  • 3,740 Answers
Check you line out distribution leads for a system ground with the #2 inverter disconnected. Also chect across the line out terminals onthe inverter with the distribution leads disconnected. The inverters use a floating ground vs and installed ground. If the inverter senses a ground your will read 120VAC to ground on each output terminal bu\out will read ZERO across the two terminals. If you read 120VAC across the to terminals with the dristribution leads disconnected and lose that output voltage with the leads connected then you have introduced a FIXED ground into the system. You will need to isolate where the fixed ground manifested itself as a result of connecting the new water heater.
Thanks for choosing FixYa.
Kelly
Posted on Aug 27, 2010
My problem is i have a jandi lite 2 and the control panel is just blinking just wondering if there is a reset button i had the heater working good then shut it down now i cant get it to work it just...
check to see if water temp sensor shorted remove to black wires from control board if it quits bad temp sensor if it doesnt bad display board need new display board
May 23, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
THE UNITS TRIPS THE POWER EVERY TIME I TURN ON THE WATER HEATER
sounds like your element is shorted out , on electric water heater heaters build up lime in the bottom and eventually the element overheats trying to heat water and burns in half, shorts out..drain water heater and kill power to it and remove your bottom element and check it out..also clean the scale out of bottom of tank with wire or something to pull it out so new element does'nt touch it when installed Good Luck!
May 16, 2011 | Garden
I turn the machine on and the light blinks and it will not heat the water. I have tried using a magnet to move the float, but the float is at the top.
Do you see a fast or a slow blink? If you see:
  • A fast blink: the machine has encountered some condition that prohibits it from engaging the heater element. This could be a low water level detection (the float being in the high position doesn't mean the Reed relais is also triggered!), some other malfunction or a power problem. To rule out the latter, plug the Senseo into another wall socket, preferrably another electric group.
  • A slow blink: your Senseo is feeling happy and is unaware of a problem. This may point to a defective heater element. If you do hear the rumbling noise of water being heated, it's most likely the temperature sensor - both are cases for the repair shop.
Sep 05, 2010 | Philips Senseo HD-7810 Coffee Maker
Piolet lite will not stay lite. Takes awhile to lite after it dose lite it kicks off again
Sounds like a bat thermocouple to me. Replace it they are not very expensive.
Good Luck,
Gil
Mar 01, 2010 | Reliance & 30 Gal LP Gas Water Heater
Went u turn it on the red lite comes on and wont turn green and wont work its a road pro rppi-1500w
Sadly replacement is the best option. It is just not cost effective to get the inverter repaired.
The cost starts out about 150.00.
Best option is to take it back to where you purchased it and hope you can get a new one.
Hope this tip helps.
Am a seven each power inverters owner.
Recommendations: Purchase a Pure sine inverter 1500 watt. We have had one of these running 24 seven for almost a year now.
Jan 07, 2010 | RoadPro AC/DC Power Inverter 2000/5000w
Im getting error code 11 and it wont fire
hihpoe i can help check gass valve is open press power button to turn off open hot water fixture and turn back on if this dose not work conntact your dealer best of luck pete
Nov 22, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
May 29, 2009 | Pentair Minimax NT Heater
Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Jan 19, 2009 | Pentair Minimax NT Heater
Electronics - Others Logo
63 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Craig Butler
Craig Butler
EE Eddie
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
