Question about Ryobi Garden
I have 3 ryobi gas trimmers that will not start, where can i take them?
  • Ryobi Master
  • 7,482 Answers
Check to make sure you have spark at the spark plug if you do then:
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
If the mower/weedeater is over a year old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, you will first need to seat the jet screws.
But before you seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Oct 12, 2010
How to start a Ryobi Gas trimmer CS26 RY26500B? I
turn switch to on possition press primer bulb 5 to 7 times choke pull rope then turn choke off
Jun 27, 2010 | Garden
Ryobi 700r trimmer does not start. Changed spark
hve you checked the HT lead and the on/off switch i had the same model as this and i changed everthing but in the end t chucked the thing away and got a sthil modle
Jun 21, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Ryobi gas trimmer stalls when lowering the revoutions
do you have the right kmix fuel to addat start on choke let run tell it dies then pump the ball on half choke and chage the plug
May 15, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi gas trimmer
I don't mean to over simplify this, but are you using fresh gas? Gas string trimmers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with string trimmers, and it fixes the problem 75% of the time.
Hope this helps!!
chad
Oct 03, 2008 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
65 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
