Question about RCA PROV801C Camcorder
I have an older RCA pro 8 video camcorder. The eject door will come open but the top piece will not go back down to close. Maybe model # is pro 865. If can't be fixed. what can I use to make old tapes into DVDs?
SOURCE: RCA PRO854 camcorder
maybe I would buy your camera,
yes as far as I know hi8 and 8mm are completely different cameras,
where are you and how much for the camera?
david@fullbliss.com
Posted on Oct 15, 2007
SOURCE: Canon zr300 ejects tapes
The solution for this required sending it to Canon factory service. I was very reluctant to do this because I've heard horror stories about Canon service, but I was actually pleasantly surprised. The total cost was only about $65 and the shipping and service turn around time was amazingly fast. I was expecting weeks to go by. If memory serves me right I shipped it and received it back in less than 2 weeks.
This is a known problem with Canon and would be covered under warranty if your time hasn't run out.
Posted on Sep 25, 2008
mistersony
  • 320 Answers
SOURCE: need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Posted on Oct 29, 2008
mistersony
  • 320 Answers
SOURCE: rca CC9360 Mini DV Digital Camcorder
Usually this occurs when the door latch release mechanism is broken. This mechanism is located on the basket where you push the tape in and it's job is to open the tape "door" on the cassette that you insert. Unfortunately, the only fix for this is to replace the cassette basket. I know your camcorder is actually made by JVC, but I don't have access to a manual so I can't supply a part number for you.
Posted on Nov 07, 2008
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
Posted on Dec 18, 2008
Tape Eject Mechanism
How much did you pay for the Camera? Want to send it to a Repair shop, or try to fix it yourself? I have links to repair manuals and one to a repair shop in Florida. Post a reply if you want those links.
Feb 10, 2014 | RCA Video Cameras
Jammed by putting tape in upside down
Take off the battery on the camcorder. Insert the battery and at the SAME time, push the power and the eject to see if this resets the camcorder so it will eject. If this does not work, I'm afraid the unit will need to be taken apart and removed manual. Good Luck
Jun 25, 2007 | Sony Handycam CCD-TRV37 Camcorder
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but...
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
May 15, 2011 | RCA CC-439 Camcorder
I have the DZ-GX5020A DVD Cam....the disc eject door will not open.....I can hear it clicking trying to open, but no luck... everthing else works fine.......can you help me?
None of those options worked for me. I had to remove the single screw on top of the camera. Then slide the silver top panel forward to remove it. Then remove the dark panel where the screw was removed. Then you should see a small metal piece very close to the DVD door opening that is holding it closed. Slowly nudge it forward to unlatch the door. This allowed me to open the door to remove the DVD. Unfortunately I still have to do this every time to get the door open. I may try some lubricant on the metal to prevent sticking.
Jul 02, 2010 | Hitachi DZ-HS300A DVD Camcorder
8mm Cassette mechanism fails to eject or sometimes fails to close
This camcorder is at least six years old now, and replacements are available quite cheaply vie on-line auction sites, probably at far less than the cost of repair.
Apr 05, 2017 | Sharp Viewcam VL-AH60U Hi-8 Analog...
Rca CC9360 Mini DV Digital Camcorder
Nov 07, 2008 | RCA CC9360 Mini DV Digital Camcorder
Canon ZR85 camcorder won't turn on
Steps for removing the tape from a totally dead ZR85:
1. Turn camera upside down.
2. Move "Open/Eject" button to full right position (toward lens).
3. Manually push tape door open.
4. On the metal surface that sits between you and the tape, there is a very small screw. There is probably a yellow sticker next to the screw that says "Do not press on this part". With a small jewelry phillips screwdriver, remove that screw.
5. Push the metal plate (with tape) in the direction ofr the door and lift slightly. The metal assembly holding the tape comes loose, exposing the top of the tape.
6. Pull the tape upwards (out of the camera). At this point, the tape will still be engaged in the play heads. With the cartridge out far enough to see the heads, reach in with your jewelry screw driver and carefully lift the tape over the heads, and free from the camera.
7. Use the eraser on the end of a pencil to wind your tape back into the cartridge.
8. When re-assembling the mechanism in the camera, there are two curved slots on both sides of the piece you took loose. You'll need to thread these onto two posts inside before you place the top back in position and put the screw back in.
May 10, 2008 | Canon ZR85 Mini DV Digital Camcorder
Tape eject door will open but tape will not eject
got door open and looked in and saw what looked like the tape head sitting very slightly proud of tape and believe it or not inserted a very thin and pointy bladed knife up as far as the head then pressed it down on top of the head very lightly and the head slid down its shaft to its original position switched camcorder back on and tape then ejected as per normal and it has worked normally since and as i did'nt touch the head (face?) no damage was done and it can record and play with no problems, a little unorthodox perhaps but it worked for me and saved me a probable fortune
Apr 09, 2008 | Samsung VP-D361 Mini DV Digital Camcorder
Canon UC1 8mm video camcorder
No solution..... but eager to know where one can get the battery packs and charger fir this camcorder (UC1) A 8 mm videotape is stuck within the camera housing and can not be ejected...No battery and charger available..
Where are those battery packs available f.i." SUNPAK RB-E77MF 6V 1700 mA ??
I would highly appreciate your advice
Thanks in advance
J.van Bochove
e-mail: jvbochove@onenet.an
Jan 05, 2008 | RCA 8MM VIDEO HEAD CLEANER (WET) 8mm Tape
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Video Cameras Logo
304 people viewed this question
Top RCA Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
