Question about Maytag Neptune MAH5500B Front Load Washer
Is there a sensor not working if there is too much water for load size
    Top Expert:
  • Maytag Master
  • 76,164 Answers
This is caused by the water level sensor either being clogged or defective
Posted on Aug 27, 2010
Is there a way to override the sensors and add more water to the washing cycle?
funny thing these NEW Fancy units aren't as smart as the old ones that only had 3 dials on them and one was load size which let us put more water in just by turning the dial . then let you have even more if wanted .
May 20, 2015 | GE Washing Machines
Not enough water in load
Level sensor is not working properly or the adjustment for load size dial is not working properly.
Mar 15, 2015 | Washing Machines
I have a Maytag Centennial top load washer. When washing in normal or heavy with large or super load size, the washer remains in sensing mode. Some water does start to fill, but never reaches wash cycle....
This unit does not handle a super large load as it advertised. When you put a super large load, the sensor is over-sized and will not move on the next cycle.
Sep 03, 2013 | Maytag Centennial MTW5800TW Top Load...
FILLS WITH WATER THEN NOTHING
There is a water level sensor switch inside the washer. This sensor
needs replacing. It tells the washer to start running when the level
of water reaches the correct amount for you load size.
You will need to call a service repair man to change the sensor.
Feb 25, 2011 | Kenmore 24032\24036 Top Load Washer
It will fill up with water and drain but won't spin or turn at all.
hello Katie,
Your water level sensor is faulted, or it could be the water level selector switch. Next time it happens, try rotating the water level selector between load sizes. If the machine then starts to agitate, then you are looking at a bad switch. If rotating between load sizes doesn't do anything else, then it could be the switch AND/OR the level sensor. The water level function locks out the motor (agitate / spin) until level requirement has been satisfied.
Sep 10, 2010 | Washing Machines
What is the acuwash sensor
Washer temperature sensors and water level settings
The temperature of your washer's water varies with your laundry care needs. Standard washer models typically feature three temperature settings: Hot/Cold, Warm/Cold, and Cold/Cold—and higher-end models often offer as many as six or seven temperature settings. Temperature plays a key role in the effectiveness of your detergent—pairing the right detergent with the right setting for your fabrics and soil is important, as this will help reduce damage, prevent detergent residue, and provide the best wash across fabric types. For the best fabric care, look for washing machines with automatic temperature control (ATC). A sensor will control water temperature and ensure cold washes are above 60 degrees (F) to dissolve detergents, and warm washes do not exceed 93 degrees (F) to help prevent shrinking and bleeding.
The amount of water you use for each load also affects washer performance. Doing laundry is a bit like a science project. You need to make sure you are using the right volume of water, with the proper amount of detergent based on the dirt level of the laundry being cleaned. Too much of one component can result in a less-than-perfect outcome. Standard washing machines allow you to select water levels for different size loads, but some models offer more water-level options. Washers with automatic water levels use sensors to determine load size and adjust water level for best cleaning and rinsing performance. You will generally find these options in higher-priced top-loading washers. A benefit of front-loading washing machines is that most come with this automatic water-leveling feature.
Whirlpool® AccuWash™ temperature control sensor provides a temperature-controlled wash.
this is an article from the whirpool website, u can get a manual printed or downloaded by going to whirlpool.com and going to owners center and typing in ur model number.......
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washing machine overflows no matter what load size
there is a sensor that tell the valve when to turn on and how much water should go thru the machine, it is a selinoid valve in the water line with a wire commming out of it,, you will either need to replace this your self or have a tech come out and tend to it
Jun 07, 2009 | GE WBSR3140DW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
