Question about Whirlpool ED5FHEXMQ Side by Side Refrigerator
I have a Whirlpool fridge freezer ART 731. The freezer is working fine but the fridge has started to get too cold and freeze the items inside although the control is at its lowest.
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Can you tell me why please?
All the big cooling happens inside freezer compartment. Freezer gives little cool air to fridge compartment. Now when the vent blocks that little cold air cannot go into fridge compartment. Thus your freezer works good but not fridge compartment. Milk goes bad but frozen meet keeps good.....
Vent freeze up either due to defrost problemt, defrost drain line problem, Evaporator fan problem or even can be your damper motor not opening due to unit failure or frozen damper door.
Sep 19, 2014 | Whirlpool GX2FHDXVY Gold Stainless Steel...
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
The freezer works well but the fridge is not cooling.
Classic symptom of: the connection passageway between the freezer and the fridge compartment
has closed off - usually due to ice buildup - or something clogging/blocking the passageway.
Your Refrigerator works by releasing cold air into only the freezer, then this cold air passes thru
a passageway into the fridge compartment to cold (but not freeze) the fridge compartment contents.
If this passageway is blocked, then just the freezer works, and cold air never makes it into the
fridge compartment. In the old days, you'd be told to defrost your freezer, since the blockage
was ALWAYS caused by frost buildup. Today, we have frost-free freezers, and your freezer may
simply have too much stuff inside - there has to be some room to allow some air flow around
items in the freezer, and whichever item is blocking the air passage to the fridge compartment -
just move it away from the passageway opening.
Mar 15, 2011 | Westinghouse Refrigerators
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Freezer not blowing air - bad smell in fridge
Your automatic defroster coil is open and needs to be replaced along with the fan in the freezer that blows the cold air around and also blows air into refrigerator.
Bad smell down below is food rotting in that section because it is not cold enough.
Mar 22, 2017 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
Freezer suddenly stopped freezing and fride is not getting cold
Hi, I would try putting your refrigerator and freezer control switches on medium. Good Luck,I hope this helps you out.
Nov 07, 2008 | Whirlpool Refrigerators
FREEZER IS COLD BUT NOT FREEZING WELL,FRIDGE IS NOT AS COLD AS IT SHOULD BE
Your freezer fan has stopped working or jammed. It's also possible that your defrost timer has stopped working and that the airways in the freezer are clogged with ice and the air can't circulate to the fridge. One of the two. Good Luck!!
barneyluc
Oct 03, 2008 | Whirlpool ET8WTKXK Top Freezer...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
Whirlpool ED5FHEXMQ Side by Side Refrigerator Logo
303 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
