Question about Avanti WC42 Wine Cooler
Avanti WC42, stopped working. Compressor (ZEL GVY40AD) is warm and tube going to radiator is very cold. Digital dash has been blinking with err for a few months but was cooling ok.
  • Avanti Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 28, 2010
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Our Coke machine door was accidentally left open for days. Because of this, the compressor is shot. $800 is a lot to throw away over a $130 compressor. Help !!!!
I would contact tecumseh refrigeration compressors. It will still cost a pretty penny to replace. Proper diagnosing tel if the compressor is shot or there is a bad part that keeps it from running
Nov 02, 2015 | American Retro AR-15002 1930s Coca-Cola...
Hello-- My Avanti refrigerator is not cool enough (it only goes down to 45 degrees). It's about 6- 7 yrs. old. Any thoughts on why that would be? Thank you.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 15, 2011 | Avanti Refrigerators
Avanti error code e2 wine chiller, what is the problem?
Display flashes Error message "E2" - Defrost sensor (Coil Sensor) failure.
Contact the Avanti Service Department - 1-800-220-5570
Hope helps.
Jun 03, 2011 | Avanti WC42 Wine Cooler
Temperature began to warm up daily until now it just stopped cooling
Hi, I tried to cross the model number you gave with Avanti and it did not do an exact cross reference.
Usually when a cooler slowly warms up the causes can be
1. The Compressor is not running at full speed or has stopped running
2. The PTC start / run relay / Klixon assy mounted on the Compressor has failed
3. The run capacitor has failed.
4. The temperature control has failed.
If the compressor is running and it is NOT cooling then there is a coolant leak or the coolant system had become blocked usually in the capillary tube area.
The current model numbers for parts are here:
http://www.avantiproducts.com/parts-accessories/current/yes
And the Discontinued model parts are here:
Just note there are many aftermarket (like part) sources that will be much cheaper than Avanti sourced replacement parts. Most repair techs would advise you to use locally sourced replacement parts.
Feb 04, 2010 | Avanti WC42 Wine Cooler
Display com., start,and run terminals on ZEL GVY40AD refrigeration compressor
0 run 0 start
0 common
or----------------------------------------------------------------------------------------
0 common
0 start 0 run
The 0's replicate the compressor pins .
Jan 01, 2010 | Electrolux Refrigerators
My boiler lights up,stays on for 1 minute then cutts out...
You could check the flame sensor is clean and the connections are tight . check the pressure switch as well. also get the over heat could be shutting off too soon ,
Check the rads for air lock ,
May 11, 2017 | Water Heaters
2000 mercury grand marquis air conditioning won't work
1st Thing,
Located Someone With a Set Of A/C Gauges 134A Freon,
Make Sure Your A/C System Has Enought Freon In It, There Is a Low Freon Pressure Switch
In The Electrical System, Usually, 50-60 PSIG or Less On The Gauges, Will Indicate Low Freon, When Freon Is Low The Compressor Is Dis-engaged To Prevent Compressor Damage.
1] Low Freon
2] Bad Low Pressure switch
3] Blowen Fuse[s]
4] Electrical Problem[s]
[a] Digital Climate Controlled ?
Climate Control Self Diagnose From Button's On Unit, OEM Manual Explains This,
If Yor Auto Has Digital Climate Control.
5] Bad Compressor DC Coil
Note: Does The Compressor Engage, Click-On When Button Is Pressed, But Getting
Only Warm Air?
Is One Of The Compressor Aluminum Tube's Cold, Be Careful Other Is Really Warm/Hot,
If Cold and or Sweating, Dripping Water [Normal], You Are Blending Hot Air w/Cold
Air At The Heater Blend Box, Making Warm Air.
If This Is So, If A Vaccum Controlled Temp Unit, Check For A Vaccum Hose Bad,
Should Be Either 1or 2 Vaccum Lines Going Into Firewall To Feed The Controller
Unit, If OK, Might Be a Bad Blend Box Diaphram, [Control's A/C air, Blocks Off
heater Coil Hot Air].
If Your Auto Is Vaccum Controlled, Can You Changed From Bottom, Dash,
Defrost Air Flow?, Yes, No Vaccum Lost Feeding Controller, Still Might Have
Bad Diaphram Blending Hot Air w/Cold If Your Have Cold Alum-Tubing In
engine Compartment.
If Digital Climate Controlled, Might have Diaphram's, Vaccum Controlled or
electrical Servo's Controlled vs Diaphram [Vaccum] Controlled.
This Might Help, Hopefully, This Is Just For Starter's, There More To Some System's
and Without The OEM Mgr's Manual[s] You/Be Would Be Lost, especially w/Electrical.
Later, God Bless
Apr 24, 2009 | 2000 Mercury Grand Marquis
Replacement for Skybox compressor
The solution is too change refrigertants, Enbraco makes the PW4.5hk11. its a little over sized and you'll need to switch to hot shot.
Mar 11, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Avanti WC42 Wine Cooler Logo
768 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
