SOURCE: Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
SOURCE: black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
SOURCE: Vertical line when using document feeder
Look really close at the small glass strip. There will be toner embedded in the glass. It will probably be a very thin streak though, so hard to see.
SOURCE: Lines appear when making a copy using document feeder tray
If the lines are vertical (in the direction the ADF feeds, 11in long for 8 1/2 by 11) You can try cleaning the glass the scanner uses when it's using the document feeder. Pull up the top left part of the printer where the documents feed, there's a little rib in the middle of the side to help you do this, then simply pull up the assembly underneath with all the rollers in it, you should see about an inch of glass underneath and a centimeter long strip of white plastic on the assembly (this serves as the white background when feeding slimmer papers) Clean them both. I'd recomend any glass cleaner, just don't spray it in there, spray it onto a cloth.
SOURCE: vertical line appears on the paper, when
I think this is due to some nozzle on the cartridge that doesn't jet because it is clogged ( hardened ink )..Try to wipe the cartridge in a damp cloth and print again..I hope this could help...
