Question about Universal Kreepy Krauly In-Ground Pool Cleaner
Areas go uncleaned on the floor - Universal Kreepy Krauly In-Ground Pool Cleaner
  • 640 Answers
If you have areas of your pool not getting cleaned when using these pool cleaners, first check to make sure that the return line water flow is correct and adjust it as necessary with the eyeball diverter valve. Also, make sure that you have enough hose to reach all corners of the pool. Check for proper hose balance.
Posted on Oct 08, 2010
Suction only comes out from hose attachment but nothing fron the bottom
Check All hoses and areas that the dirt goes through. Sounds like a plugged spot. Especially the dirt picker upper at the floor. All areas.
Mar 03, 2017 | Vacuums
Lifefitness elliptical. How do I fix a squeaky pedal?
There are several areas that could create squeaking in an elliptical,
  • Check the floor where your elliptical sits to verify the floor is level. An uneven floor could create strain on moving parts which would create squeaking
  • Spray an aerosol multipurpose lubricant onto any moving joints, especially metal on metal high friction areas like bolts and washers.
  • Apply grease around the rollers on the roller arms beneath the pedals. Operate your machine to spread the grease onto the roller ramps. Wipe away any excess grease.
Synthetic grease works best and will last you longer also.
I will be attaching a link to the grease we recommend, if any other questions come up please do not hesitate to call on our Tech Support Team at 888-713-2280 or visit us online at www.sportsmith.net
http://www.sportsmith.net/itemform.aspx?item=P0000SUPELUBE02&ReturnUrl=%2fproductsearch.aspx%3fdsNav%3dN%3a751055
May 28, 2015 | Exercise & Fitness
Dogs and hampton bay laminate flooring
Yes, you can count on that. But if you leave urine uncleaned constantly.... flooring should be the last of your problems.
Apr 03, 2013 | Hampton Bay Laminate Tile & Stone...
What are the differences between bamboo and solid wood floors?
Bamboo is much more environmentally friendly than solid wood as bamboo regenerates in time. Moreover, bamboo is harder than some solid woods such as red oak and black walnut.
Feb 06, 2013 | Building Materials
How can I prevent my hardwood floor from scratching?
You can put throw rugs down in any high traffic areas such as in entryways, in front of your sink or refrigerator. Moreover, you can dust, sweep or mop on a regular basis to keep any dirt or debris from collecting on the surface or the floor.
Hi my washing machine samsung WA10U3 top load. After wash always filter check. Why?
because the function of filter is to block the small particles or dirty things including grease or oil etc., before disposing the water, and to avoid the clogging of floor drain and even sewage line. And after you used it you should check the filter if theres a some dirt, and grease or oil to clean up to avoid clogging and unclean water from your washing machine
Feb 06, 2011 | Samsung SW62ASP Top Load Washer
Roomba has been scratching my hardwood floors.
My brand new Rhoomba worked perfect the first time. The second time using it, I was aghast to come home to the same issue.
My marble floors now have long scratches across the wide expanses of floor. In the areas where the rhoomba (I witnessed it doing this motion the first time I let it clean) does those small geometric patterns like in confined areas, those same geometric patterns appeared scratched into my marble floors in my condo!!!!
What's worse? They do not intend to do anything to repair the damage....just refund my money.
R---I---P O----F----F! DO NOT BUY ONE!!!!!!!
Jan 31, 2010 | iRobot Roomba 560 Robotic Vacuum
Uncleanable
printer clean unable 46 . troubleshooting and routine maintenance
Oct 12, 2008 | Brother DCP 130C All-In-One InkJet Printer
Crunching and grinding
That noise come from the pump that drived the water out the drum. Since you don't have this noise every time, it's seems like it's cause an unclean filter issue. Cleaning the filter - should solve this issue. Before openning the filter, prepare a bowl and a floor cloth to avoid water's flooding. Good luck !
May 24, 2006 | Hotpoint First Edition FEW12 Front Load...
Universal Kreepy Krauly  In-Ground Pool Cleaner Logo
115 people viewed this question
Top Universal Pool & Spa Experts
Bill Jordan
Are you an Universal Pool and Spa Expert? Answer questions, earn points and help others
