Question about Maytag M3DH30B2A Dehumidifier
My dehumidifier is squealing
My Maytag dehumidifier runs frequently and from time to time starts squealing. If I smack the casing the squealing stops for a while. Sometimes it stops for a while temporarily.
I'm unsure whether it's a good idea to take the plastic casing off to see whether if there's any way to fix the problem inside.
  • mark thompson Jun 04, 2008
    Same problem, fixed for a couple of months by adding hi-temp/ hi-pressure grease to the motor bushings. Temporary fix. Squealing returned and then the fan motor stopped working at all although it does spin freely. Suspect humidistat control now? Turning the control to run-full-time does not work, either. Light does come on so unit has power. Heard there was a recall on these units from someone who bought the product at BJ's. Any ideas?
    Genius:
  • 1,073 Answers
The fan motor is the cause it needs to be replaced
Posted on May 06, 2008
It is loud vibrating when comp. runs if I tip the unit up 3or4 inches it stops vibating is this ok too run this way?
No, not really. As the unit has to be in a level position to operate properly and not overflow.
If the unit is sitting on carpet, this will often times cause the vibration noise. I don't know why, but it does and it does with my 4 year old LG unit. I have noticed, that once the tank reaches the 1/2 full point, it will vibrate sometimes. I solved the problem by firmly smacking the left & right sides of cabinet at the same time, with my open hands. The vibration stops immediately and continues to run until it shuts off because, the humidity extraction level has been reached or the tank is Full & needs to be emptied.
It's a simple solution, but it works. I hope it works for you and thanks for choosing FixYa.
Aug 23, 2011 | LG LHD459EL Dehumidifier
I PURCHASED MY DEHUMIDIFIER CA 2 YRS AGO. ONLY USE IT OCCASIONALLY IN MY GARAGE IN THE SUMMER. RUNS FINE, BUT DOES NOT COLLECT ANY MOISTURE IN THE BUCKET. WHAT COULD BE THE PROBLEM? Thanks
check to make sure the compressor is running. try smacking it 5/6 times with a hammer while it's running, surrounding lights should dim for a second, should have low hum sound. This solved my problem
Jul 21, 2011 | Whirlpool AD25BBK Dehumidifier
Our maytag and dayton humidifiers all starts but no water collects in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 02, 2011 | Maytag Dehumidifiers
My dehumidifer collect water but the fan blows hot her so it makes the room hotter
This may be caused by running the unit in continuous mode, rather than timed mode. The heat is generally is generated when the defrost mode cycles on, to defrost the cooling coils. This happens more frequently, if the air space around the unit is obstructed or it's operating in a temperature range of 40 to 60 F. Cleaning the air intake filter at least once a week, can help solve this problem, too.
Maintain a minimum of 12" free air space around all sides of the dehumidifier. Use a timed mode rather than a continuous mode. Make sure the room is within the proper operating temperature range and clean the air intake filter weekly.
Hope this helped you troubleshoot and solve the problem.
May 28, 2011 | Maytag M7DH65B2A Dehumidifier
My Maytag dehumidifier runs but does not collect water in the tray. Instead, it appears to leak from the bottom and ice formed near one of the side portions. Please let me know what you think is the...
This one has a leak in the refrigerant system... it will need to be found, fixed, and recharged...which will cost more then a new one...in most cases.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
May 13, 2011 | Maytag Dehumidifiers
Hello :) There is a tube that is hanging out of the back of the dehumidifier... so I need this to operate it? Can I use without it?
is there an internal storage tank for that unit. It is probably the drain tube for condensate. Put it into a bucket, run it, and see it water accumulates. If so, that's what it is, and must be put into a bucket, that then must be emptied frequently.
Oct 07, 2010 | Maytag M7DH65B2A Dehumidifier
My Maytag 45 pint model M7DH45B2A dehumidier stops working before the bucket is full. The bucket is around 20-30% full, the dehumifier will stop as if the bucket if full. I empty the bucket and reseat...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Aug 25, 2010 | Maytag M7DH45B2A Dehumidifier
Maytag m7dh65b2a freezes up ,
Found the instruction book and by reading the setting it allowed the machine to shut off before it freezes up.
Thank you.
May 28, 2009 | Maytag M7DH65B2A Dehumidifier
Maytag dehumidifier runs all the time
if your dehumidifier is under warranty, call 1-866-629-8241. they are no longer honoring the warranties, because fedders, the company that made the dehumidifiers went bankrupt. but they will prorate your warranty and send you a check. we had two months to go on our warranty and they gave us $14 and change back.
May 02, 2009 | Maytag M3DH30B2A Dehumidifier
I have a DE50P Always dry dehumidifier. It runs for vawhile, and then freezes up. It just startted doing this. How do I stop this from happening? Jim Rogers jamesrrogers2@aol.com
I dumped this piece of garbage and bought a new one from a company I trust at half the price I paid for this DeLonghi piece of ****.
Jul 21, 2008 | Maytag M7DH45B2A Dehumidifier
Maytag M3DH30B2A Dehumidifier Logo
287 people viewed this question
Top Maytag Dehumidifiers Experts
Michael Van Der...
Michael Van Der...
Bill Long
Steve
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
