Question about Sears Kenmore Refrigerator Replacement Water Filter 9002
Kenmore refrig/freezer model 106.9758615 Ice cube maker permits incoming water to overflow the resevoir.
I am not sure this is the right refrig. I have a model 253.78259800 top freezer with a model JD-21 ice maker. The ice bucket keeps filling up with a solid piece of ice. It makes and drops cubes, then water...
there s a adjustment but it only controls /like 1 to 2 oz of water . its prbably the ice mker unit or the water valve . .. ice mker tell water how long to let water in and if valve is bak it might not shop off causing water fill . change water valve first . then ice maker if needed .. icemker might have a bad tray and some cubes do not drop / if so next fill will over fill causing problem . mm
Dec 07, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Freezer stopped making ice cubes
Pour about 2/3 cup of water into the ice maker . If it dumps , then replace the dual water valve behind the refrig . If it does not dump the frozen cubes , replace the ice maker .
Sep 27, 2009 | GE Refrigerators
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a Kenmore refrig./ model# 363.9741714
The problem is actually not the ice maker itself. The problem is the electric solenoid valve in the rear bottom of refrigerator. If you follow the water line on the back of the unit down to the bottom and replace the valve that it is connected to then your problem will be solved. Hope this helps. Good luck cj2176.
Jul 25, 2009 | Kenmore Refrigerators
Code on door says er dH on Kenmore elite refrig
This error code has something to do with a defrost sensor and happened after an extended power outage. I unplugged the refrig and it reset itself!
Jul 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Kenmore freezer on the bottom. Ice-maker switch is turned on but no ice is being made?
Check your incoming water line for kinks. Make sure the water valve is turned on.
Replace the water filter.
Check inside the freezer and make sure the ice maker power cord is plugged in.
Mar 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is making hollow ice cubes, some only half frozen
Most ice makers have an adjustment screw to control the cube size. Its usually hidden behind a plastic panel on the front of the ice maker. A quarter turn either way and some trial and error testing should get you pointed in the right direction to your ideal ice cube.
Nov 05, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker quit making ice
your refrig has a built in bypass in the filter housing so yes it will work with out a filter in place. if you have not replaced your filter in the last 6 months that is likely the problem. Hollow cubes are usually a sign of not enough water getting into the icemaker then it cycles too fast and harvests hollow cubes.
when the hollow cubes fall into your bucket they bust and put water in with your cubes freezing them together. so by solving your water supply problem you'll solve most of your icemaking issues..
Dec 19, 2007 | Kenmore 64802 Top Freezer Refrigerator
Ice maker not filling & making ice cubes
First give me the entire model # on the sticker from the inside of the fridge and I can definitely help you with this.  Let's solve it before you rate it.
Oct 17, 2007 | Kenmore 50522 / 50524 Side by Side...
Sears Kenmore Refrigerator Replacement Water Filter 9002 Logo
142 people viewed this question
Top Sears Refrigerators Experts
Mike Carew
richie46
Are you a Sears Refrigerator Expert? Answer questions, earn points and help others
