Question about Acer Aspire 5050-3242 Notebook
Can't switch off
My Acer screen has frozen and now looks a bit like the video channel on a TV, ie two broad white vertical series of lines. I cannot switch off conventionally, or by the on/off switch, or by closing the lid. Has anyone else had this problem?
Look forward to your solutions
Thanks
  • 111 Answers
This normally is caused by faulty Memory specially if your laptop depends or is getting shared Memory from the RAM.
recommended solution: Try to remove theMemory/ies and clean the contact using a soft pencil eraser. Make sure that you lean both sides nd avoid touching them after cleaning.If yu have done this and still have same problem try to remove and alternately install the memory one at a time. If still same problem I suggest you bring your unit to the nearest shop to do Advance Hardware checking.
Posted on May 20, 2008
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
There is a white broad line on the left half of the TV when it's switched on.what could be the problem? LED model LG LE4500
Hi, I had a similar problem with my plasma tv.
I fixed it buy taking off the back panel then at the bottom there is another panel. Under that panel are the ribbon connectors for the vertical picture.
Looks like your 2nd ribbon has the problem. Maybe it has come losses, not sure but pull the 2n ribbon out and plug it back in. Or if you pull out the first connector ad leave it out then turn the tv back on ad see if that leave another plank part of the tv. If so then u have found your problem.
Jan 25, 2013 | Televison & Video
Westinghouse LCD TV - broad vertical green and blue lines
try to go to the factory reset and see if that helps. If not, you can then check your connection. if you use component (red, green and blue for video and red and white for audio), make sure all the color matches when you plug it in. if everything have been checked then you need to replace the main board and it should correct the problem.
Jun 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Samsung LN-S4692D - Vertical lines (>15) & static on screen
this sounds like a scan board gone ,, if you check ebay youll see two things,
1, other tvs for sale with the same fault (It might give you a clue to the fault ie , which board )
2, the same tv as yours with a broken screen ,
i dont know how good you are with taking things to bits but i personally would buy the tv with the broken screen and start swapping over the internal boards ?
Have you checked your home insurance policy for broken tv,s
it may have fell of its stand when you were'nt looking?
May 16, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Mar 23, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
chake to make sure it is hooked up right and not lose
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
Screen only showing single line of video in center.
hi there, is the single line horizontally or vertically? if horizontal line, you do have a vertical section problem, check some parts at vertical section, the vertical ic, the power source of vertical section ie diode & resistors. ty
Dec 26, 2007 | Zenith Z32X31D 32" TV
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Vertical line running through video channels 1-4
Interchange the video channels 1-4 and 5-7. Now check white vertical line in video port 5-7. Suppose you get problem remove cable television cable from tv during another two port running. These type problem occurs only when RF disturbance from cable television or video ochannel ports cable wire ground problem. I found there is no problem in tv. External source only the problem. I hope above details give you the better solution.
Aug 23, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Acer Aspire 5050-3242 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
