Question about Texas Instruments TI-30XA Calculator
What is 28 times cot 30 - Texas Instruments TI-30XA Calculator
  • Texas Instru... Master
  • 7,993 Answers
Use the relation cot(30) =1/tan(30).
Press [DRG] to set the correct angle unit (degree, radian, or grad). If you are working with degrees the DEG display indicator should appear on screen
You then type
28 [/] ( 30 [TAN] ) =
Posted on Aug 31, 2010
What time check-in Friday 01 September 2017 NZ7735 operated by Virgin Australia VA807
Melbourne to Sydney, so 2 to 3 hours before departure. 04:30 should be good at that ungodly time of day..
Melbourne · Mon, August 28 Sydney · Mon, August 28 Scheduled departure Terminal Gate Scheduled arrival Terminal Gate 6:30 am 3 - 7:55 am 2 32
va807 status Google Search
Aug 27, 2017 | Time Computers & Internet
Is it a nice idea to buy a baby travel cot for our 6months little one?
Yes, you can purchase it. These baby cots should be purchased with a lot of care and it should be of best brand.
One of the reputed online stores that you can prefer to buy these baby cots at best deals is Baby Sleep Pod.
They would provide you a large variety of high-quality cots, for which you can see the reviews from the link provided above.
Jun 11, 2016 | Graco Contour On The Go Travel Cot...
What are the best tips for buying baby cots online?
Knowing the small things and tips will help you buy a right cot for your baby. Here we provide some useful tips regarding how to buy the baby cots:
1. Doing a small research regarding baby cot at online will provide the best information regarding types and designs of baby cot.
2. You must look for the adjustable and portable baby cot which adjust the size according to baby grown up.
3. Select the baby cots colour which matches in the nursery room.
4. You also take a suggestion of your friends as well relatives If they purchase a baby cot.
5. Decide the space In the room where you place baby cots and buy a baby cot regarding the space of the baby room.
6. Try to buy a stylish and classy baby cot for your baby, which ensures the Australian standards
Jan 27, 2016 | Baby Gear
How do i collapse hauk travel cot the buttons dont seem to respond to pressing ?
push both buttons in at same time lift up then pull handle that's in bottom of cot
Feb 26, 2015 | Baby Gear
What is the torque spec for a 2003 jeep wrangler 2.4 connecting rods
  • ENGINE 2.4L
DESCRIPTION
N·m
Ft. Lbs.
In. Lbs.
Balance Shaft Carrier to Block-Bolts
54
40
Balance Shaft Gear Cover-Double Ended Fastener
12
105
Balance Shaft Sprocket- Bolt
28
250
Balance Shaft Chain Tensioner-Bolts
12
105
Balance Shaft Carrier Cover-Bolts
12
105
Camshaft Sprocket-Bolt
101
75
Connecting Rod Cap-Bolts
54 +1/4 turn
40 +1/4 turn
Crankshaft Main Bearing Cap/Bedplate - M8 Bolts
34
250
M11 Bolts
41 +1/4 Turn
30 +1/4 Turn
Crankshaft Damper
136
100
Cylinder Head Cover- Bolts
12
105
Flex Plate to Crankshaft
95
70
Flywheel Mounting Bolts
81
60
Engine Mount Bracket Right-Bolts
61
45
Exhaust Manifold to Cylinder Head-Bolts
23
200
Exhaust Manifold Heat Shield-Bolts
12
105
Intake Manifold - Lower -Bolts
28
250
Oil Filter
20
15
Oil Pan-Bolts
12
105
Oil Pan Drain-Plug
27
20
Oil Pump to Block-Bolts
28
250
Oil Pump Cover Plate-Bolts
12
105
Oil Pump Pick-up Tube-Bolt
28
20
Oil Pump Relief Valve-Cap
41
30
Spark Plugs
28
Timing Belt Covers - Front Covers to Rear Cover-Bolts
12
105
- Rear Cover-Bolts
12
105
Timing Belt Tensioner Assembly-Bolts
61
45
Sep 27, 2014 | Cars & Trucks
Ques1...3:28::5:? Ques 2.... 12:30::20:?
Q1: can also be written: 3 = 5
28 x
solving for x;
x = 5*28 = 46.7
so 3:28::5:46.7
Q2: can also be written 12 = 20
30 y
solving for y;
y = 30 * 20 = 50
12
so 12:30::20:50
Nov 06, 2012 | Vivendi Excel@ Mathematics Study Skills...
Calculate 28 cot 30
If you remember that by definition cot(theta)=1/tan(theta) your expression can be calculated as 28/tan(30). Use parentheses if necessary to enclose the whole tan(30) factor.
Before calculating any trigonometric function make sure that the angle unit is set correctly. In your case I presume that 30 means 30 degrees. Use the [DRG] key to cycle through the angle units.
Aug 23, 2010 | Texas Instruments TI-30XA Calculator
(1+cotx-cosecx)(1+tanx+secx)=2
I shall attempt :D
1) cosec A + cot A = 3
we know that (cot A)^2 + 1 = (cosec A)^2
Hence, (cosec A)^2 - (cot A)^2 = 1
thus, (cosec A + cot A) (cosec A - cot A) = 1
3 (cosec A - cot A) = 1
(cosec A - cot A) = 1/3
(cosec A + cot A) = 3
Summing them, 2 cosec A = 3 1/3
cosec A = 6 2/3 = 5/3
sin A = 0.15
Thus, cos A = sqrt (1 - (sin A)^2) = 0.989
2) Prove that (1+tan x - sec x)(1 + cot x + cosec x) =2
expand
LHS= 1 + cot x + cosec x + tan x + 1 + tan x cosec x - sec x - sec x cot x - sec x cosec x
We can calculate that
tan x cosec x = sec x (since tan x = sin x / cos x)
sec x cot x = cosec x
so the above is
LHS = 1 + cot x + cosec x + tan x + 1 + sec x - sec x - cosec x - sec x cosec x
LHS = 2 + cot x + tan x - sec x cosec x
LHS = 2 + cos x / sin x + sin x / cos x - 1 / (sin x cos x)
LHS = 2 + [{cos x}^2 + {sin x}^2 - 1] / (sin x cos x)
LHS = 2 (proved)
May 12, 2009 | ValuSoft Bible Collection (10281) for PC
What are the correct tyre pressures for a 2008 Audi A3 1.6 Petrol 5-door hatchback?
Audi A3 Recommended Tyre Pressures 1.6 96 - Onwards 28 28 32 40 1.8 96 - Onwards 28 28 32 40 1.8 SE 96 - Onwards 28 28 32 40 1.8 Sport 96 - Onwards 28 28 32 40 1.8 T Sport 96 - Onwards 28 28 32 40 1.8 T Quattro Sport 00 - Onwards 28 28 32 40 S3 99 - Onwards 30 30 36 40 1.9 TDi - 110bhp 96 - Onwards 30 30 36 40 1.9 TDi - 130bhp 01 - Onwards 28 28 32 40
Mar 25, 2009 | 2008 Audi A3 S Line Hatchback
I have a 2007 Audi A3 5 door hatchback Special but no handbook was included when I bought the car. My problem is that I do not know what the tyre pressure should be for this car and having had the car for...
Look inside the petrol cap! Otherwise:Audi A3 Recommended Tyre Pressures 1.6 96 - Onwards 28 28 32 40 1.8 96 - Onwards 28 28 32 40 1.8 SE 96 - Onwards 28 28 32 40 1.8 Sport 96 - Onwards 28 28 32 40 1.8 T Sport 96 - Onwards 28 28 32 40 1.8 T Quattro Sport 00 - Onwards 28 28 32 40 S3 99 - Onwards 30 30 36 40 1.9 TDi - 110bhp 96 - Onwards 30 30 36 40 1.9 TDi - 130bhp 01 - Onwards 28 28 32 40
Telephoned Audi Main Dealers around Manchester – Macclesfield very helpful, others either disconnected or not answering. Manual costs £21.85 (inc. VAT) + postage .... Too big to actually download and print, I suspect!
Billy Boy
Mar 22, 2009 | 2007 Audi A3
Texas Instruments TI-30XA Calculator Logo
123 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
