Question about Car Audio & Video
2007 avalanche rear speakers have no sound output. I don't believe they both could blow at the same time.... the rear radio is not on so it isn't that muting it. Is there some issue where they may mute and not unmute?
I too have no sound from rear speakers...I bought speakers thinking they were simply not there. Went to install them and found that there all of a sudden was sound there. Put the rear door panel back on and it still worked until the next day. No sound from either side on rear again. I read somewhere that a seatbelt could be damaging a wiring harness causing it so I took off the panels covering the seat belts and found no way that the harness could be damaged from the belt. Weird how they worked momentarily when i had the pass rear door panel off though.
Posted on May 16, 2011
Testimonial: "I didn't return to this site thinking I got no response. I thank you for the response and am sad to say my Avalanche has been replaced with a VW!"
2008 avalanche intermittent sound from speakers.
if its the doors then the seal on the speakers is letting water in and shorting out the speaker and causing the other speakers to do the same as the amp is being overloaded over time you will need a new radio as it will blow the amp in it. safety device will not keep saving the amp.
Dec 05, 2013 | 2003 Chevrolet Avalanche
My driver side door speakers both front and back will not work on my 2003 Chevy Avalanche and also the passenger side in the back is not working also
Did they ALL stop at the same time?
Are you running an AMP?
It sounds like your Radio Settings, Radio Internal Failure or a Wiring Fault on the REAR of the Radio..
Apr 09, 2013 | 2003 Chevrolet Avalanche
2004 Chevy avalanche right side & rear speakers sometimes it works or no sound from them . I just replaced the radio this weekend an I still have the same problem HELP.
You have a lose wire on the speaker or a bad connection on the speaker. Trace the speaker wires back and locate the short.
Oct 10, 2011 | 2004 Chevrolet Avalanche
Radio plays but no sound. Last week or so I would be riding along and the speakers would lose sound, if I switched the radio output switch to either of the radio output to speaker select positions, it...
With the 07, you may have vibration damage to one of the main boards interlayer traces.
There are issues on those bikes that will need to be checked and the radio will need to be repaired
Contact Iron Cross Audio for options
www.ironcrossaudio.com
Jul 03, 2011 | Harley Davidson 426290 AM/FM Radio
I'm installing an aftermarket radio in my 2003 avalanche with a GMOS-04 interface. It has two sets of RCA lines, however my radio only has one set of RCA cables. I'm only getting sound from the rear...
If the stereo you are using only has one set of outputs for the rear you will have to get an auxiliary AV adapter for the front speakers that has an AV jack on it so you can use the AV jacks for the front as well. This is not hard and not expensive but it is necessary. The adapter you buy will depend on the radio you are using as it will plug right up to your radio. So I am posting a link to a place I use and you can choose the adapter you need based on your radio. http://www.crutchfield.com/S-ZimO2BBIZ8j/g_50900/Auxiliary-Input-Adapters.html
Mar 23, 2011 | Interface 4 Amplified Gm Systems
Where can i find a wire diagram for my 2002 avalanche
Here is your diagram
2002 Chevrolet Avalanche Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jan 16, 2010 | Car Audio & Video
The radio was pulled off the wiring 2005 Chevy avalanche. How do I match the after market plug to the wiring in the truck? I have the 71-2003-1 parts but the colors do not match.
2005 Chevrolet Avalanche Car Stereo Installation Guide
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Dark Green
Car Stereo Amplifier Location: Under the Center Console.
Hope this will help you, good luck
Jan 05, 2010 | 2005 Chevrolet Avalanche
Truck Radio/CD Player, no sound coming out of speakers
Have you check the mute mode, maybe it is in mute mode.
Jun 01, 2009 | 2003 Chevrolet Avalanche
Car Audio & Video Logo
298 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
