Question about Car Audio & Video
Fault code 2510- Volvo xc90. - Car Audio & Video
SOURCE: removing turbo on Volvo XC90
Can a volvo 740, run with out the turbo?
Posted on Sep 10, 2009
griff842000
  • 9 Answers
SOURCE: 6720, A011, 112B, 4490, 5F11,1144 - Volvo XC90 -
here is the fault read out page for most volvos http://volvospeed.com/vs_forum/index.ph ... =66705&hl=
hope this works for you if not send email to me griff842000@yahoo.com
Posted on Oct 21, 2009
SOURCE: cigarette lighter does not work in my volvo xc90
I have seen car chargers that would blow the fuse. They were shorted out so look in the fuse box and replace the accessorie fuse and retest
Posted on Nov 17, 2009
  • 860 Answers
SOURCE: 2007 Volvo XC90 fault codes-ECM P030000, P030100,
first code means random/multiple misfire cylinder (s) detected
second code means misfire detected number 1 cylinder, third code, miss=fire number 3 cylinder fourth code misfire number 4 cylinder
causes can be spark plugs, HT leads, ignition coils, injector, wiring fault, low compression/ engine mechanical fault
Posted on Jun 04, 2010
SOURCE: How to replace timing belt for volvo xc90 2.5 turbo?
hi ineed helf to set cam shaft timing on 2003 volvo xc 90 t9
Posted on Mar 24, 2011
What could be causing my car to surge when I put it in reverse and sometimes in park?
Surging is usually associated with a fuel/air fault, or maybe a leak in the vacuum pipe.
However, I do believe that the XC90 may suffer from a transmission fault. Have a look on the following links:
Transmission Failure Common Volvo XC90 Common Drive Train Problems
http://www.matthewsvolvosite.com/forums/viewtopic.php?t=40707
Mar 28, 2016 | 2005 Volvo XC90
After changing the camshaft sensor on a Volvo 2004 xc90 do I have to reset anything
I would clear the engine fault codes and go on a 10 mile+ test drive, just to verify the problem is solved.
Mar 03, 2015 | Volvo Cars & Trucks
EGR cut off - disconnect
the fault codes would come up and the car probably would not run right.
Jan 04, 2014 | 2009 Volvo XC90
2006 Volvo XC90 AWD V8 with H7 halogen headlights always displays 'headlight bulb failure' warning even though my headlights are both working fine. How do I fix this?
Try to check the bulb on the light unit the fault is given,checking the connector,or even renewing the bulb,probably the resistance of the bulb is down in bright but can not noticed. It had happened to a customer of mine on a BMW 528i ,even the lights were working fine,I renewed the faulty stated by the vehicle ECU and then the warning on the dash gone.
Nov 01, 2013 | 2004 Volvo XC90
I'm working on a 2007 volvo XC90. I replaced the
You may have to go to your local Volvo dealer tech department. They have a complete list of the codes!
Jan 11, 2013 | Cars & Trucks
I have a code p1652 for my volvo 2004 xc90 can someone tell me is this a computer problem
P1652 or ECM982A: Manufacturer controlled computer output circuit, Engine control module (ECM) internal fault. (Permanent fault, can't clear without a code reset)
Nov 22, 2012 | Cars & Trucks
Volvo xc90, warning comes up ''engine service required'' then loss of power until warning goes off.
Hi.
The loss of power can be caused by a big number of different fault. A code reading would be a good first step to troubleshoot the fault.
If the check engine light comes on, then engine faults have been detected and related codes have been stored in the vehicle's computer modules. Primary DTC (trouble codes) are stored in the main computer (called ECU). Such codes can be read using an OBDII code reader connected to the socket under the dash. Here a code reader: U480 Can Bus.
A code scanning can also be performed at the dealer place or at any garage. In US it can be done for free at the nearest Autozone.
If there is no indicative codes also test the fuel pump and pressure regulator by reading fuel pressure with a gauge connected to the port on the fuel rail. Here the tool: Wilmar W80594.
Regards.
Ginko
Oct 22, 2011 | 2003 Volvo XC90
How do i get rid/ reset message xc90 "transmission service urgent" i have already taken to volvo dealer about six months ago. they could not pin point issue on diagnostic. Cheers
You first have to retrieve fault codes from your computer network then you have to diagnose the systems/circuits indicated by the fault codes to determine what the cause of the failure is, then you must repair the system/circuit at fault and then reset the computer system. If the dealer cannot do this, I don't know who can. Did they tell you what fault codes they were getting? If so, we can look up the troubleshooting charts for those codes as well as do a Technical Service Bulletin (TSB) search to see if this is a known problem with a known fix. Without the codes, your guess is as good as mine.
Sep 11, 2011 | 2004 Volvo XC90
2007 Volvo XC90 fault codes-ECM P030000, P030100, P030300, P0304000, what do they mean?
Jun 04, 2010 | 2007 Volvo XC90 V8 AWD Sport
Sep 28, 2009 | 2005 Volvo XC90
Car Audio & Video Logo
59 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
