Question about Troy Bilt Tb70ss Gas Trimmer
Will my ryobi 725r attachments fit the troy built tb70ss
SOURCE: ryobi 2 cycle gas trimmer 705r/725r
You can buy the gas filter that comes with the hose for less than 10 bucks.
Posted on Aug 31, 2008
SOURCE: I NEED A REPAIR MANUAL FOR RYOBI 725R TRIMMER
Hey go here http://safemanuals.com/user-guide-instructions-owner-manual/RYOBI/725RE-_E
it's free...
Earl
Posted on May 08, 2009
connertamago
  • 37 Answers
SOURCE: Troy-Built TB70SS, 1 year old, will not start even after carb cleaning
check to see that the kill button is not stuck in the contacting position, and if it is, try to get it unstuck. WD40 should help. if it's not, then disconnect the kill wires. now try starting it. if it still doesnt start, then the spark generator is bad. if this is the case, you'll need a new trimmer, or have a small engine mechanic replace the generator. i think its called the coil, not sure at the moment it's 4:00 am for me. anyways, whichever is cheaper is best choice.
Posted on Jun 01, 2009
  • 10865 Answers
SOURCE: Troy-Bilt TB70SS will not start
Hi. Go to any auto parts store and get a can of starter fluid. Have a helper squirt a little into the air cleaner while u start it up. Then continue to squirt the starter fluid to keep it running until the engine sounds good again. J.
Posted on Jul 07, 2010
SOURCE: I have troy built string trimmer model
how to replace pull cord
Posted on Jul 29, 2010
Spark plug for Ryobi 725r trimmer
take the one in it out and check the numbers on it
May 19, 2018 | Ryobi Garden
How to replace troy built tb25cs primer bulb?
The primer bulb has two clips that fit into a slot. You will have to squeeze both clips to pull it out. Make sure you remember which fuel hose went on each nozzle of the primer. There are two nozzles. Make sure you put the fuel line back on the same way. The part # for the bulb if you need it is a Walbro 188-512-1.
May 27, 2014 | Troy Bilt Tb70ss Gas Trimmer
How to get the fuel tank off the troy built Tb70ss gas trimmer
Go here and you will see the parts breakdown and diagram for this model...to give you an idea on the parts you will be working on:
http://www.ereplacementparts.com/troybilt-tb70ss-41adt70c711-gas-trimmer-parts-c-26780_27267_27463.html
Aug 26, 2010 | Troy Bilt Tb70ss Gas Trimmer
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 08, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
725r trimmer
You can buy new Line to re-spool on your existing head
Aug 17, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing Drive Shaft for a Ryobi 725r
The lower flex shaft should cost around $40, unless you order it online and have to pay shipping. You should be able to get one from your local MTD dealer. (Ryobi is owned by MTD)
May 25, 2009 | Ryobi Garden
TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
May 07, 2009 | Troy -Bilt String Trimmer/Blower...
Troy Bilt Tb70ss Gas Trimmer Logo
563 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
