Question about Desa International White Wireless Plug In Door Chime
How do you get the brass cover off the door bell button to check the contacts and battery
  • 28 Answers
The cover for checking the batteries should be located on the back side of the push button case. You should be able to remove it by sliding it open (can be difficult) like cell phone battery covers.
Posted on Sep 01, 2010
Chevy Venture 2002: power sliding door want open using buttons. Electric motor will engage and open door when outside door handle is used. Door closes fine electrically using button or handle.
Try using steel wool to clean the contacts for the door. Open the side door. See the brass pins sticking out from the door? Clean those. Then look at the plate with brass squares near the bottom of the door opening, where the brass pins would eventually make contact. Steel wool those too. Might make a couple of little sparks but don't worry. See if that helps.
Sep 13, 2017 | Chevrolet Venture Cars & Trucks
Need lighted door bell button
Illuminated bell buttons were very popular in the old days of mains transformer driven standard door bells. The bell coil needed quite a lot of current to drive it and so connecting a small lamp across the button contacts did not affect the bell or button operation and allowed enough light to illuminate a small nameplate or just the button for easy location at night.
This allowed standard 2-core bell wire to perform both the function of bell operation and button illumination. For electronic type door bells it illumination of the bell button is needed either a 3 or 4 core cable would be needed or a separate lamp, something perhaps like a welcome home lamp that is operated by a pir.
Freidland was the principle manufacturer in the UK and is still a popular choice for quality equipment but I expect similar equipment was or is available all around the world.
Oct 16, 2015 | Home Security
Diagram for connecting a battery operated door chime to push button
IF you are going all elec,you need a door bell,bell transformer and of course the push button. This is all low voltage so phone wire will work.You are just using 1 pair of wires so pick a pair such as the blue pair.Wire from push button to transformer to door bell.It is not polarity senstive....simple to do
Mar 17, 2015 | Cars & Trucks
I have a Paget Trading wireless door bell. How do you get into the door bell button. Is there a battrey in it?
Yes, there is a small battery in the door bell button, use a small screwdriver to carefully pry it apart, make sure the transmitter and receiver are on the same frequency and within range of each other.... really hope this helps?
Feb 22, 2015 | Bell Sports Wireless Door Bell with...
Id like to change song on my doorbell Dimango model 4330 r cd chime reciever
The webpage http://www.dimango.com/dc-cd-quality-doorbells.htm
shows:
Wireless Doorbell CD Quality Door Chime
Model RC4300
No longer do you need a wired door chime or traditional doorbell with brass tubing to get amazing, rich sound. Our Battery Operated Door Chime from Dimango has CD quality sound while remaining completely wireless...
  • Plays three selectable sounds
    1. Ding Dong
    2. Dong
    3. Westminster Chime Click To Hear Sound!
  • Set sound conveniently at button
It seems that there is a button on the receiver/speaker. Try press once and see if the sound changes.
Nov 27, 2013 | Desa International White Wireless Plug In...
I have a desa DD100S wireless door chime but for some unknown reason the bell push is not working, I have tried replacing the battery but still unable to ring chime. The actual base unit is fine and...
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mar 09, 2011 | Desa International White Wireless Plug In...
Bell does not ring
Have you changed the battery in the outside push button switch? If not, I suspect that may be the problem. Also, the contacts may be dirty from the weather of insects that can work their way into it.
Remove the cover, change the battery if necessary and clean off the contacts.
That should take care of the problem.
Feb 17, 2011 | Desa International White Wireless Plug In...
Button Press (Not Remote) Normal Door Bell Makes Slight Buzz Only
The electromagnet that causes the bell clapper to move when the circuit is closed by pushing the button is failing. Replace the bell unit.
Jul 07, 2009 | Desa International White Wireless Plug In...
Desa International White Wireless Plug In Door Chime Logo
77 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
